H22 Stroker Engine update.... 2point6
Old Jul 9, 2005 | 12:15 PM
2point6's Avatar
Default H22 Stroker Engine update.... 2point6
Set-up: As of 7/9/05
Car: 1990 Accord 4 door Lx
Engine Block: '93 H22a "bored and stroked" to 2.44ltrs of displacement built by Collective Racing. Custom 98mm Crank (Balanced and nitrited), 89mm bore Darton sleeves, Crower Pro-billet rods, Custom 12/1 compression 89mm JE pistons, Prodrive oil pump, ATR crank pulley, manual timing belt tensioner conversion, ARP main studs.
Cylinder head: Ported and polished by Collective Racing, Web Cams camshafts (89/267), Web Cams springs and Titainium retainers, ITR LMAs, Modified stock intake manifold, Hondata intake manifold gasket, Erick's Racing 70-68mm Throttle body, RC engineering 440cc Fuel injectors, B&M fuel pressure riser and Guage, STR cam seal, STR cam gears, SMSP 4-1 header, ARP head studs, Cometic head gasket.
Transmission: T2T4, prodrive 4.7 FD, carbon synchros
Misc: AEM 3" cold air intake, NGK wires, Hondata S200, 2 1/2" crunch bent exaust.
Just an update: My engine has curently hit 56K miles, 3% leakdown cylinders 1-4, Dynoed 241.8 WHP and 188.8WTQ (on a Dynapak) and still driven hard all the time. It will be an interesting comparison with my upcoming new engine set-up. Changes to my current engine to date are: Intake manifold changes from the Euro R to a modified stock manifold, factory aluminum oil pan, and I shimmed my oil pump. During the dyno passes, I was seeing 110+psi oil pressure at 8K RPM. I feel this is slightly high and can be robbing me of a few HP compared to my earlier dyno passes. The manifold changes seem to be working nicely as well. Just to note, my previous dyno reading were made on a dynojet. I am told that the dynapak reads slightly lower in HP (about 10whp), but can be configured to read almost the same as a dynojet if the measurement is based on time of acceleration. I don't know if this makes it easier to compare my progress, but I thought I should note it. My readings were not measured in time of acceleration. Over all I feel this engine has been very consistant in power output over the years and has proved to be fairly reliable, depending on your outlook. My new set-up should prove that a larger displacement can be equally reliable... we will see
Old Jul 9, 2005 | 02:06 PM
brandond's Avatar
B A N N E D
Default Re: H22 Stroker Engine update.... 2point6 (2point6)
let me be the first to say niceee....cant waitt o see this build outcome very interested keep it up 2point6
Old Jul 9, 2005 | 03:05 PM
N_A_is_best's Avatar
Default Re: H22 Stroker Engine update.... 2point6 (brandond)
all i can say is tiiiiiigggghhhhht!!!!
Old Jul 13, 2005 | 09:17 PM
onepoint6i's Avatar
Default Re: H22 Stroker Engine update.... 2point6 (N_A_is_best)
are you still running the balancer shaft? just curious, many people say these thing rob a bit of power? dunno.. im a b-series guy lol.. nice build btw..good luck
Old Jul 14, 2005 | 05:23 AM
93H22ACX's Avatar
awesome man! How much displacement will your new motor be, 2.6L?
Old Jul 14, 2005 | 05:26 AM
Innovation's Avatar
Default Re: H22 Stroker Engine update.... 2point6 (93H22ACX)
2468cc, a baby 2.5
2point6
31
Feb 27, 2006 09:39 AM
Civic 1.8
Feb 12, 2006 09:27 PM
2point6
Dec 15, 2005 01:03 PM
2point6
Jul 12, 2005 01:29 PM
2point6
Nov 28, 2002 08:05 PM
