My Worst Nightmare!!! PICS inside
Now the first thing i want to explain to you guys is that i made the biggest mistake off my life in buying a car (when i had very little experienc) that was already built.
Okay, so after driving this car for about 4 months we biggin to notice white smoke coming heavily from the exhaust, shortly after i notice that v-tec wont ingage until 8000k rpms. At that point i new something was wrong, so i took the car to Full Function Tech
, who have been really helpful for me since the problem started, and they did a leakdown test. Here are the results:
Cylinder #4 - 30%leak Appeared to be rings
Cylinder #3 - 3%leak
Cylinder #2 - 98%leak Intake valves
Cylinder #1 - 10%leak
So i decided to pull the head because we knew that something was obviously wrong.
Here are the pics:
valve cover off:
head off:
Cylinder #4
Cylinder #4 Piston
As you can see cylinder #4 valves look different(burninige very rich maybe?)
Close up of #4 valves
Close up of #3 valves
I was mainly wondering if you can determine from the pic if i will need to go overbore or just hone the cyldinder walls?
And if i will need new valves?
So ill take any input and suggestions and advice you guys have!!!
, who have been really helpful for me since the problem started, and they did a leakdown test. Here are the results:Cylinder #4 - 30%leak Appeared to be rings
Here are the pics:
valve cover off:
head off:
Cylinder #4
Cylinder #4 Piston
a machine shop will be able to tell you if they are able to bore the cylinder over within a safe spec. they will also be able to perform a vacuum check on the head to see if you will need any new valves.
based upon your numbers, you may need to save up some cash and get ready for a rebuild. sorry it had to happen that way.
Jeremy at Redzone recommended Gilroy Automotive Machine to me. I just dropped my block off there today, even though hes not open. He went out of his way so i could drop it off. When i get it back you can see for yourself if he does quality work
I believe that rob's shop was the one that they said they sent all their motors for machine work too? Maybe not but they did mention that they would send it to someone else for the machine work.
HELP ME DECIDE
<A HREF="https://honda-tech.com/zerothread?id=1311136
" TARGET="_blank">https://honda-tech.com/zerothread?id=1311136
</A>
</A>
YoungMoney_Twit
Jul 9, 2018 02:23 PM
wildoutwhitegsr
Jun 24, 2008 09:59 PM
CPR
Aug 7, 2004 02:14 PM
