Road Racing / Autocross & Time Attack Road Racing / AUTOX, HPDE, Time Attack
Camera mount position ...
Old Feb 15, 2002 | 10:55 AM
JinMTVT's Avatar
New User
Default Camera mount position ...
where do you guys would better like to have camera mount positionned at in a prelude ?
i was thinking as far back as possible..and as high as possible
i removed the side rear belts cover on the rear pillars
to see if it would be easy to make mounts that would be hold by the belt holders in the rear..but it is almost impossible with the configuration of the car..without damaging the plastic of the car..
so i am thinking of making it go between both middle pillars attached to the front belt holder...replacing the large black washer that is there ...
and the bar would then bent backward and up and come straight at about 1.5foot behind the seat belt holder and almost to the top ..camera would have to be mount reverse though if the clip is on the bottom ..
what do you think ?
thanks.
Old Feb 15, 2002 | 11:05 AM
JG Luder's Avatar
Default Re: Camera mount position ... (JinMTVT)
This isn't a great place for this question.. Now the comp forum will probably give you a host of answers. Granted they may be sarcastic..............
Transfered.
Old Feb 15, 2002 | 11:22 AM
Crazydave's Avatar
Default Re: Camera mount position ... (JG Luder)
Put the camera in the grill.. and put a piece of plexiglass / lexan in front of it.
otherwise in the back seat as far back.. make sure you get the mirror in the camera too...
if you are racing... point the camera backward ... watch the people behind you... It's amazing to see what goes on...
Old Feb 15, 2002 | 12:21 PM
johng's Avatar
~Sarcastic answer~
I used my roll cage for a mount and recommend you do the same.
Seriously, the camera needs to be mounted securely. I've seen some pretty creative mounts using the passenger seat head-rest holes. Don't mount it too far back otherwise all you'll see is the two front seats with little view out the front windshield. What ever you come up with, you better be sure it stays put and passes tech. You'd be better off getting at least a harness bar from Speedware Motorsports and using a camera mount from I/O Port Racing.
Old Feb 15, 2002 | 12:27 PM
B18CJDM's Avatar
Default Re: Camera mount position ... (johng)
Yeah, i'll have to agree w/ Johng on this one, here's mine, Speedware Motorsports harness bar w/ IoPort Racing camera mount.
Speedware Motorsports Bar w/ IoPort Racing camera mount
[Modified by B18CJDM, 1:31 PM 2/15/2002]
Old Feb 15, 2002 | 01:04 PM
Crack Monkey's Avatar
Just behind the plane of the front seats usually works well (mounted in the cross brace of a rollcage is an example). This usually gives a good view out the windshield and can be adjusted to see driver hands.
Like alread ymentioned, the mount must be secure. And the camera should be strapped in as well (in case the tripod mount hole strips/cracks). A strap through the camera's handle and then around rollbar or other metal should be ok).
Old Feb 15, 2002 | 06:15 PM
JinMTVT's Avatar
New User
Default Re: Camera mount position ... (Crack Monkey)
ok cool thank you guys
yes that is what i thought of too ..making a little net of metal wires and use a racing pin to secure it into something.. so if the mount breaks or something u don't get a flying all around camera
ahha
thanks again
Old Feb 16, 2002 | 05:08 AM
MechE00's Avatar
for autocross, I've got that headrest camera mount.. with a wide angle lense, it works well. with a safety strap, I don't worry too much about it becoming a projectile at autocross.. if you're at the track, I don't think I'd trust it, though.. and then I'd agree with the roll cage choice.
Old Feb 16, 2002 | 03:11 PM
Aahj's Avatar
Default Re: Camera mount position ... (MechE00)
I just made a camera mount today that bolts to the headrest.
I will post pictures up shortly.
the camera angle is good. I would just like to buy a wider angle lens.
later,
aj
Old Feb 17, 2002 | 05:39 AM
MechE00's Avatar
Default Re: Camera mount position ... (ajn)
ajn: don't forget a safety strap of some sort for that camera.. it won't pass autocross tech without one if the tech people know what they're doing..
Old Feb 17, 2002 | 06:29 AM
illusion's Avatar
ntpog.org
Old Feb 17, 2002 | 06:12 PM
Aahj's Avatar
Default Re: Camera mount position ... (illusion)
I just bought my wide angle lens today.
Here are some pics of the camera mount I made too.
enjoy
http://www.imagestation.com/album/pi...?id=4292035717
B_Swapped93
May 30, 2013 08:34 PM
ShinyNewPenny
Aug 9, 2007 06:32 PM
momentarily
Jul 26, 2007 01:27 PM
swappedcx
Dec 24, 2005 04:11 AM
ludetech
Oct 18, 2004 10:33 AM
