sway & tie, can u have both?!?!
Old Jul 9, 2005 | 05:12 AM
peshte's Avatar
Default sway & tie, can u have both?!?!
can you have rear sway and tie bars? on an EG? i saw a pic of TrackSol's 1994 del Sol Si...and it doesnt look like you could have both. if only one can fit, what's better?
Old Jul 9, 2005 | 07:16 AM
allanonjj's Avatar
Default Re: sway & tie, can u have both?!?! (peshte)
try the suspension forum
Old Jul 9, 2005 | 07:36 AM
fasthatchb18c1's Avatar
yes you can
read this it might help you decide which one you want, theres more if you search
https://honda-tech.com/zerothread?id=1298894
Old Jul 9, 2005 | 04:04 PM
peshte's Avatar
Default Re: sway & tie, can u have both?!?! (fasthatchb18c1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fasthatchb18c1 &raquo;</TD></TR><TR><TD CLASS="quote">yes you can
https://honda-tech.com/zerothread?id=1298894</TD></TR></TABLE>
that doesnt talk about whats better...or if u can have both...thx tho.
Old Jul 9, 2005 | 04:07 PM
litterbox's Avatar
I am a (Trial User) Army
Get an itr bar (22mm) and an ASR subframe brace and you'll have the best.
http://www.a-spec-racing.com
Old Jul 9, 2005 | 05:01 PM
Street Ghost's Avatar
Default Re: sway & tie, can u have both?!?! (litterbox)
or you can get a comptech rear sway/tie bar combo.
Old Jul 9, 2005 | 05:26 PM
Kyles ej1's Avatar
Default Re: sway & tie, can u have both?!?! (Street Ghost)
u can have both, they just have to be made to work together. like right now i have a neuspeed tie bar and want a sway bar too but i dont think i can. it depends on what kind u get. ive seen them before though, as a mattor of fact i saw one the other day in A/C
Old Jul 9, 2005 | 06:58 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by peshte &raquo;</TD></TR><TR><TD CLASS="quote">
that doesnt talk about whats better...or if u can have both...thx tho.</TD></TR></TABLE>
Well when it comes to just putting a sway bar on your car around 22mm or bigger you will tear the sub frame, If you go with ST speed tech or Comptech they come with a brace that will fit over your sub frame and have a tie bar to reinforce it. You can also go with a ASR and a ITR sway bar(also 22mm). Mainly I don't think a tie bar by itself will do any good with a sway bar if you don't have a good brace for the sub frame.
Old Jul 9, 2005 | 07:16 PM
peshte's Avatar
Well when it comes to just putting a sway bar on your car around 22mm or bigger you will tear the sub frame, If you go with ST speed tech or Comptech they come with a brace that will fit over your sub frame and have a tie bar to reinforce it. You can also go with a ASR and a ITR sway bar(also 22mm). Mainly I don't think a tie bar by itself will do any good with a sway bar if you don't have a good brace for the sub frame.</TD></TR></TABLE>
tear the sub frame? seriously? how? waht brace should i get?
Old Jul 9, 2005 | 07:48 PM
Your sub frame will tear because it is a thin piece of metal and I have seen it plenty of times when you use just a thick sway bar on a EG. Repairing it is a bitch as well
The ST speed tech and comptech come with one and ASR is a just a brace that you can add a sway bar too. Beaks kit is one also but I have heard a lot of pll tearing there sub frame with it.
Old Jul 9, 2005 | 09:18 PM
sinister6's Avatar
or you can choose SRR
Old Jul 9, 2005 | 09:33 PM
peshte's Avatar
Default Re: (sinister6)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sinister6 &raquo;</TD></TR><TR><TD CLASS="quote">or you can choose SRR</TD></TR></TABLE>
whats srr?
Old Jul 9, 2005 | 09:36 PM
litterbox's Avatar
Default Re: (peshte)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by litterbox &raquo;</TD></TR><TR><TD CLASS="quote">Get an itr bar (22mm) and an ASR subframe brace and you'll have the best.</TD></TR></TABLE>This man speaks the truth.
Old Jul 11, 2005 | 08:12 AM
sinister6's Avatar
whats srr?</TD></TR></TABLE>
This one
Old Jul 11, 2005 | 08:15 AM
pinoyrnr's Avatar
see you can have both. i have ST rear sway and a JIC rear lower tie bar. it works great.
Old Jul 11, 2005 | 02:15 PM
peshte's Avatar
so if i got that would i have to change the sub frame ?
Old Jul 11, 2005 | 02:27 PM
Mrfeee1's Avatar
yes you can heres an example
pic is a bit dark but you can see she sway bar over the tie bar its black.
Old Jul 11, 2005 | 03:19 PM
Default Re: (Mrfeee1)
I'm guessing that's a 19mm sway bar, if its any bigger I wouldn't take your car to a autocross track. Since I don't have much experience with this kind of bar you don't have to take what I say to heart but that doesn't look like enough to me(if your using 22mm or bigger)
Old Jul 11, 2005 | 04:49 PM
peshte's Avatar
Default Re: (fasthatchb18c1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fasthatchb18c1 &raquo;</TD></TR><TR><TD CLASS="quote">I'm guessing that's a 19mm sway bar, if its any bigger I wouldn't take your car to a autocross track. Since I don't have much experience with this kind of bar you don't have to take what I say to heart but that doesn't look like enough to me(if your using 22mm or bigger)</TD></TR></TABLE>
so 19mm isnt big enough? and if i get 22mm i should get a sub freme brace?
Old Jul 11, 2005 | 04:57 PM
It's not that 19mm is not enough it will show improvement but 22mm is thicker and would be stiffer. I haven't had a 19mm to know how big a difference it would make but I wouldn't use the srr with a 22mm bar. If you get the standard ST bar I think that is 17 or 19 honestly im not sure. If I were you I would go around other forums and take multiple ppl's opinions on what they have had experience with before you buy anything.
Edit: the reason for my comment about the ssr is that I cant find any feedback on this bar and it doesnt look that well designed for a swaybar in my opinion
Old Jul 11, 2005 | 08:56 PM
doughboy_88's Avatar
take the guesswork out and go with Comptech. It's pretty expensive though...$400. Comptech has a "new" hardware upgrade kit b/c of a redesign in how the endlinks are attached; if you decide on Comptech, get the new ones directly from them since it'll come with the upgrade already.
Otherwise, it's $60!
philosofy1
Suspension & Brakes
May 16, 2005 03:07 PM
I3iggy
10
Jan 23, 2004 09:53 AM
ntrinsik
Jun 21, 2003 01:42 PM
asmallsol
Apr 23, 2003 09:59 PM
asmallsol
Mar 30, 2003 07:57 PM
