how to re-wire jdm to usda harnesses together for swap?
Old Jul 8, 2005 | 11:01 PM
EG93si's Avatar
Default how to re-wire jdm to usda harnesses together for swap?
i just ordered my engine (b16a out of the si-r 2) which is obd1 just as my 93 si hatch is. Steve from hmotors told me i need to cut my harness and rewire it due to the right hand drive issue. what does that all involve, and whats the easiest way to go about it. can you just re "set" the pins from the jdm harness in to the usda plugs if thats even what hes talking about. diagrams always app., i learn better with pictures
Old Jul 9, 2005 | 05:36 AM
VTECVillain's Avatar
Default Re: how to re-wire jdm to usda harnesses together for swap? (EG93si)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EG93si &raquo;</TD></TR><TR><TD CLASS="quote">Steve from hmotors told me i need to cut my harness and rewire it due to the right hand drive issue.</TD></TR></TABLE>
You will reuse your stock Si harness, it has all the necessary wiring already there for the swap except for the knock sensor plug which is only 1 wire. You will want to salvage the knock sensor plug and wire from the JDM harness and add it to your stock harness. It's much more easy than you are making it.
Old Jul 9, 2005 | 11:07 AM
WHITFIELD-TUNED's Avatar
DYNO-PRO
From: SoCal I.E 909, CA, where we innovate not immitate
Default Re: how to re-wire jdm to usda harnesses together for swap? (VTECVillain)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by VTECVillain &raquo;</TD></TR><TR><TD CLASS="quote">
You will reuse your stock Si harness, it has all the necessary wiring already there for the swap except for the knock sensor plug which is only 1 wire. You will want to salvage the knock sensor plug and wire from the JDM harness and add it to your stock harness. It's much more easy than you are making it.</TD></TR></TABLE> exactly you will just need to extend a few wires and run the wire for the knock sensor if you are using a p30 ecu ... by the way you run the knock sensor wire to position D3 on the ecu
Rok_Stok
12
Mar 1, 2009 02:37 PM
Totall Insane
Jul 6, 2006 06:47 PM
GMR*Spork
Jun 3, 2006 11:47 PM
hughesl
Aug 7, 2003 05:11 PM
JDM CTR '00
Sep 25, 2002 10:20 PM
