Sputtering and wont start.
Old Jul 8, 2005 | 10:09 PM
matix's Avatar
Default Sputtering and wont start.
The car started sputtering a couple of days ago. If i would hit the gas a little over about 10% throttle it would start bogging. I then saw a sparkplug wire was loose and fixed the sputtering. Now 2 days later it came back. Now its not the wires they are all in tight. It is wierd if i keep the throttle at 10-20% and at higher revs i can accelerate otherwise it will bog and sputter like im at a revlimiter.Instantly when i go wot it sputters. Then i stopped to check it out and now the car wont even try to crank. The only sound it makes when i turn the key is the main relay click and the fuel pump turning on. This really made me mad bc first it starts sputtering now the starter wont even try to crank it over. I went back today and push started but it still was sputtering really bad. I parked it and need to figure this out. Please help. I was thinking clogged cat now from the missfires, tps,clutch switch.
Old Jul 9, 2005 | 07:21 AM
matix's Avatar
Default Re: Sputtering and wont start. (matix)
Help i need to get this car started.
Old Jul 9, 2005 | 12:47 PM
matix's Avatar
I figured it out. The reason it wouldnt start was bc my clutch sensor went out. I just jumped the connector now it starts. Then I just did a full tuneup wires,plugs,cap,rotor,fuel filter,and pcv valve. It now runs like a champ.
pyroom
Aug 1, 2011 07:51 PM
Tad
Jan 3, 2006 06:37 PM
CivicHP
Jun 1, 2005 02:27 PM
SpdFrk
15
Jan 14, 2005 05:13 PM
Audio28
Dec 21, 2002 01:06 PM
