B17 Dyno 224 WHP @ 12 PSI
Old Jul 8, 2005 | 08:41 PM
Ri5e's Avatar
Default B17 Dyno 224 WHP @ 12 PSI
224 whp @ ~12 PSI
B17 stock bore
CP 10.0:1 Pistons
DSM 450 cc injectors
Inline Pro 2mm headgasket
Inline Pro exhaust manifold
3 Inch downpipe/exhaust system
V-AFC tuned
T3/T4 turbo (Came off of a Drag Gen 3 turbo kit)
My friend had his B17 dynoed today and he was dissapointed that the numbers came out low. Would a SC61 and Hondata fix this problem?
Old Jul 8, 2005 | 08:55 PM
kleefton's Avatar
Yea they are very low. Should make around 270 at that boost level depending on the compressor trim. I say get some adjustable cam gears to try and get that thing to make some more power.
Old Jul 8, 2005 | 08:58 PM
Blazin Civic's Avatar
Default Re: (kleefton)
Something is very wrong....check the compression and then get a retune on some real engine management.
Old Jul 8, 2005 | 09:07 PM
Tchleung's Avatar
Yeah those are way low... I hit 270whp on my b16 with SC34 at 11psi. you should easily see high 200's
Old Jul 8, 2005 | 09:16 PM
blackeg's Avatar
Default Re: (Tchleung)
yea ill agree something is awry here. any abnormal oil comsumption or smoke or anything? compression test might help out. good luck with everything
Old Jul 8, 2005 | 09:47 PM
darkdayz's Avatar
Default Re: (blackeg)
yeah get that thing checked out asap....I made 241@ 5.5 lbs on a stock b18c1
Old Jul 8, 2005 | 09:48 PM
Drew Peacock's Avatar
You will need to do something with the timing I suspect, so no a bigger turbo wouldn't but hondata most likely will.
Old Jul 8, 2005 | 09:55 PM
Tchleung's Avatar
een still on the AFC hack he should make more power then that I'd think.
Old Jul 9, 2005 | 12:17 AM
DLB1994's Avatar
Default Re: B17 Dyno 224 WHP @ 12 PSI (TurboSmart)
do you have a chart with rpm not mph , somethings up should make a lot more power u dont need the headgasket , put a oem one back on
Old Jul 9, 2005 | 06:40 AM
Ri5e's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by blackeg &raquo;</TD></TR><TR><TD CLASS="quote">yea ill agree something is awry here. any abnormal oil comsumption or smoke or anything? compression test might help out. good luck with everything</TD></TR></TABLE>
ah yes, forgot to mention, purple smoke comes out when he hits the boost hard. But when he's driving normal, there is no smoke. I'm guessing this is a matter of how it was honed. he will get the compression checked out today...
Old Jul 9, 2005 | 06:51 AM
USDM 4G VTEC's Avatar
thats very low
i made 235whp at 10-11 psi
Old Jul 9, 2005 | 07:17 AM
RobbieG35's Avatar
12 Years Strong
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Tchleung &raquo;</TD></TR><TR><TD CLASS="quote">een still on the AFC hack he should make more power then that I'd think.</TD></TR></TABLE>
Thats what I was thinking
Old Jul 9, 2005 | 07:33 AM
SOHC_MShue's Avatar
I would think that he would make more power than that with the afc hack unless the timing was being increased so much that it exceeded the knock threshold. Are you sure it isn't pinging or anything?
Old Jul 9, 2005 | 07:48 AM
blackeg's Avatar
Default Re: B17 Dyno 224 WHP @ 12 PSI (SOHC_MShue)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SOHC_MShue &raquo;</TD></TR><TR><TD CLASS="quote">I would think that he would make more power than that with the afc hack unless the timing was being increased so much that it exceeded the knock threshold. Are you sure it isn't pinging or anything? </TD></TR></TABLE>
exactly. check the spark plugs, perhaps its seeing inaudible detonation, or the motor just was not broken in well/rings did not seat properly.
and purple smoke??? sure its not blue? also, i know the motor is built, but the a/f seems to be in the 12-12.5:1 range. doesnt that seem a little lean especially with all the timing in the maps from the hack?
Old Jul 9, 2005 | 08:07 AM
SOHC_MShue's Avatar
Default Re: B17 Dyno 224 WHP @ 12 PSI (blackeg)
Purple smoke is what happens when you do drugs. Drugs are bad mmkay
Old Jul 9, 2005 | 08:59 AM
JDM_Risa's Avatar
answer is tuning and get a better fuel mangement...crome or hondata...
10:1 c/r, 84mm
itr cams
stock head
@12 psi yield 332whp w/
60-1 garret turbo
but most definately you should be 270+++
try doing a compression check... you know its not ignition problem since your dyno is pretty consistance and solid no gaps in powerband
Old Jul 9, 2005 | 09:23 AM
G
sh!t happens.
Default Re: B17 Dyno 224 WHP @ 12 PSI (GunMETAL_TEgRa)
Thats some low numbers on the hax. I boosted my b17 2 years ago with a rev hard kit and sc34 and vafc hax with 450 injectors. I had it on 10psi all the time and it felt good at the time. I never dynoed it, cause i poped a head gasket and bent valves..
What are the specs on the turbo and and who tuned it?
Old Jul 9, 2005 | 09:52 AM
Ri5e's Avatar
Default Re: B17 Dyno 224 WHP @ 12 PSI (G"UNIT)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by G"UNIT &raquo;</TD></TR><TR><TD CLASS="quote">Thats some low numbers on the hax. I boosted my b17 2 years ago with a rev hard kit and sc34 and vafc hax with 450 injectors. I had it on 10psi all the time and it felt good at the time. I never dynoed it, cause i poped a head gasket and bent valves..
What are the specs on the turbo and and who tuned it?</TD></TR></TABLE>
I'm not sure about the specs on teh turbo. It's my friends car and he got the turbo off of a Drag Gen 3 kit...
Inline Pro tuned it
Urugly
Jun 18, 2006 10:03 AM
11psiTurboSI
Jul 21, 2003 10:00 AM
Type-ARR
Jun 30, 2003 05:20 PM
