e-manage ??
Old Jul 8, 2005 | 07:45 PM
tfnaaf's Avatar
Default e-manage ??
When making changes to the settings section do you need to do an update on the main unit ? After reading the below on http://emanageforums.com/forum...?t=29 What are the possible effects if this isnt done? And what is accomplished by re-updating the main unit each time? Is this still needed with the latest updates ?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote">1) Turn your car to ON
2) Go to the FILES section of the yahoo group and download the latest
US
language and the latest Main unit operating system.
3) Bring up your support tool to ONLINE
4) Go to COMMUNICATION and click on MAIN UNIT UPDATE
5) When it prompts you to TURN OFF MAIN UNIT, turn your key to OFF
position.
6) Click OK
7) Turn ignition to ON
8) Bring up your support tool to ONLINE.
9) Go to SETTINGS and click on PARAMETER SETTINGS
10) Make all your changes and select relevant maps. If you do not have
the additional harnesses, check the "Air Flow Adjustment Map". Also set
your Throttle Setting.
11) Click on CONFIRM. It will pop up asking you to turn off ignition
once. Go ahead and turn ignition to OFF. Click OK.
12) Turn ignition to ON. Reconnect support tool so it is ONLINE.
13) Go to COMMUNICATION and then click on EXPORT DATA.
14) Once that is done, click on CONFIRM for any pop ups you get. Then
turn the ignition to OFF.
15) Turn the ignition to ON and proceed to turn the car ON.
From this point on, NEVER reconfigure the PARAMETER SETTINGS or export
to main unit!!! This is what screws things up.
Any change you make on your air-flow map are automatically updated with
the main unit thus there is no need to "export".
Every time you start up your support tool and want to modify the maps
on the main unit, just IMPORT from the main unit and proceed to modify
it.
But again, never mess around with the PARAMETER SETTINGS or EXPORT to
main unit unless you go through the steps above again.
Old Jul 8, 2005 | 07:57 PM
tfnaaf's Avatar
Default Re: e-manage ?? (tfnaaf)
one other question, What is the relationship of voltage output of the greddy map sensor to actual boost/vacuum ? Is there a chart or way to figure out X volts = how much boost/vacuum ?
Modified by tfnaaf at 9:09 PM 7/8/2005
Old Jul 8, 2005 | 09:06 PM
Qveon's Avatar
n/m
91akira
Jan 18, 2011 02:52 PM
Mr.Speed
Dec 19, 2008 01:07 PM
CiViC I2aCeI2
Jan 5, 2006 01:07 AM
triple_s1x
Feb 27, 2005 11:10 AM
sxecustoms
Jun 11, 2003 07:47 PM
