has anybody upgraded to an ITR intake manifold?
This is on a first gen B16.
experiences, results, impressions, worth it? what would be recommended as far as the throttle body is concerned, use ITR, bore out stock one?
Just thinking about what I should do right now before putting the B16 back together. Thanks
We got mine in without major issues... you'll need a short bolt pattern IACV, or just use one bolt and tighten the **** out of it
That worked for me until I found the right style one in the parts bin,... which was about 6 months, no idle issues.
I put on a 2nd gen JG overbored to 64mm Throttle Body, and got intake manifold and Throttle Body used off a turbo car that was parted out as a package for <you can hate me now> $225
We tapped the stock map port on the OBD1 throttle body and just made a vacuum port out of it for my map sensor signal.
Here's a closeup with another piece we used when the tapped one started to mess up... I think we got this piece from FMAX... not sure.
[Modified by SiR Kid, 6:01 PM 2/15/2002]
That worked for me until I found the right style one in the parts bin,... which was about 6 months, no idle issues.I put on a 2nd gen JG overbored to 64mm Throttle Body, and got intake manifold and Throttle Body used off a turbo car that was parted out as a package for <you can hate me now> $225
lmiguelvv
31
Aug 29, 2005 05:25 PM
B16EJ
Jan 11, 2004 12:07 AM
RedRex8
May 28, 2003 09:52 PM
