d series turbo?
I used a z6/b7 on my project i need to get it tuned soon but i also used the apexi kit. But good luck on your build mang.
But for a stock motor the Z6 and Y8 are the best i think.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Elite Hatch »</TD></TR><TR><TD CLASS="quote">How much boost can they take with proper fuel/timing managment on a stock motor.</TD></TR></TABLE>
how ever much boost it takes to yield about 200whp on a stock internal motor.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Street Ghost »</TD></TR><TR><TD CLASS="quote">
how ever much boost it takes to yield about 200whp on a stock internal motor.</TD></TR></TABLE>
For the turbos listed above you can get 200whp with about 10psi
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Machine1 »</TD></TR><TR><TD CLASS="quote">I'm running 15 psi with a small T3 and turboedit. No power numbers, only track times. </TD></TR></TABLE>
15psi on stock internals? How long have you been running this setup? and any 1/4 times? I see the 1/8 times on your sig
It's a stock Y8 block/Y7 head with a Cometic headgasket and ARP studs.
The car was put together by us in June of 2004 and has been running 13+ lbs with an afc setup.
I recently got it back a couple months ago and switched it to TurboEdit and adjusted the boost a little.
1/4 mile times will be in August when the track opens back up.
We're going to the 1/8th mile tonight to see if we can better the time.
