Newer Skunk 2 Camber (Do I still need to replace the boot?)
So, I just purchased the new Skunk 2 Camber Set. I know the older version's boot would tear or fail after awhile and ppl replaced the boot with the OEM boot. Does anyone know if the newer Skunk 2 camber's boot need to be replaced with the OEM boot as well? If yes, what is the part numbers needed to replace the boot?
I haven't seen the newer style arms but I wouldn't doubt that they didn't change the boots.
Take the one off the skunks and go to your honda dealer. If they are the same size (height wise) you're probably good with the skunks. If the Hondas are bigger than buy them and swap.
Part number for the oem boot
51464-S04-013 BOOT, BALL JOINT
JohnX6
Oct 11, 2005 03:24 PM
ichibano
May 25, 2003 12:09 AM
