Question about Non-Toda gears on toda cams
Old Feb 15, 2002 | 08:42 AM
xjohnx's Avatar
Default Question about Non-Toda gears on toda cams
has anyone had and problems using non toda cam gears on toda spec b cams?
Old Feb 15, 2002 | 08:56 AM
B2FiNiTY's Avatar
Default Re: Question about Non-Toda gears on toda cams (xjohnx)
I don't see why you would have a problem with using non-toda stuff.
Old Feb 15, 2002 | 09:00 AM
slivic's Avatar
Default Re: Question about Non-Toda gears on toda cams (B2FiNiTY)
Never had any problems on spec B's
b00st-0wnz's Avatar
From: Drinking Beer in sunny FL and jamming to Skid Row, USA
I would suggest asking the All Knowing Mr Search. You can locate him on the upper right of your screen. Merely click on his Name, enter your question (or part of it, such as "toda cam gears" or "toda cams" and you will not only find a thread discussion skunk2 gears with toda cams, but info about the toda cam gears coming with different bolts, etc. Mr Search is very smart. (When he's not at lunch)
xjohnx's Avatar
Neither did i, until i saw this on Toda's site.. Can't tell if it's a ploy to sell more cam gears or if there is any validity to it..
Some aftermarket campulleys use connecting bolts that are not compatible with TODA camshafts. The use of these bolts could damage the TODA camshafts. If you plan to use TODA camshafts, we only recommend using TODA campulleys to prevent damage to the camshafts.
Old Feb 15, 2002 | 09:10 AM
Lip's Avatar
Lip
i guess it could be possible that another manufacturer has produced cams and pulleys for the honda and used a different thread for the cam gear bolt. not sure if this is true or who if so...but thats my guess
Old Feb 15, 2002 | 09:26 AM
sgT's Avatar
sgT
Default Re: Question about Non-Toda gears on toda cams (Lip)
to my knowledge nobody sells bolts with their cam gears with bolts other than
toda. So reusing the stock bolts is fine.
Old Feb 15, 2002 | 09:28 AM
xjohnx's Avatar
Default Re: Question about Non-Toda gears on toda cams (sgT)
Ok, question #2, do you think it's worth it to upgrade to the bronze valve gudies sold on jdmhondaparts.com? since the head will be apart to put the springs/retainers in anyway?
Old Feb 15, 2002 | 09:31 AM
RStoR's Avatar
For what it is worth, my OE bolts did not work with my Toda 1st Gen. gears. The OE bolt has a lip that extends past the bolt head just slightly. This lip ground into my valvecover when we used them. The Toda supplied bolt did not have this lip and didn't hit the cover.
Old Feb 15, 2002 | 09:33 AM
sgT's Avatar
sgT
xjohnx: no.
RStoR: that reason was brought up before so yes with the toda gears, using their
bolts is probably necessary if you dont cut your cover. i havent had problems
with skunk gears and stock bolts though
Old Feb 15, 2002 | 09:35 AM
B18CXr's Avatar
I agree, Toda gears seem to be the only gears that need the "thinner head" bolt
if a non-cut valve cover is used.
Old Feb 15, 2002 | 11:24 AM
VTEC4GS's Avatar
I took some pics of the differnce in offset when NOT using toda gears or stock gears (which no one would use anyway). There is about 1mm more width on some aftermarket gears so when torque the 12mm bolt it puts added stress on the part of the camshafts which can cause to break.
The closest you can come to the stock width of the inside of gear that goes over camshaft, the better off you are, thats the short answer.
Greg
Old Feb 15, 2002 | 11:40 AM
itr0045's Avatar
Default Re: Question about Non-Toda gears on toda cams (vtec4gs)
I ran Skunk2 gears on my Spec B's. They worked fine. Of course they want you to buy their stuff so they are going to recommend their products over someone elses.
Beto_619
Apr 14, 2017 06:00 PM
Tarzan
Dec 21, 2010 12:28 AM
powerfulperformance
Jun 24, 2009 09:46 AM
