NEED HEL ASAP!!!(clutch change)
ok... all the mounts are disconnected, theres no more bolts holding the tranny to the block, and i still can't get the tranny to slide off the block... i'm out of ideas..
From: San Diego, I miss Chicago, but love SD, CA, US of fuckin A
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MiMiK »</TD></TR><TR><TD CLASS="quote">at this point. the tranny will fall, but the motor goes with it..</TD></TR></TABLE>Depending on what motor setup you have there will be bolts in the rear mount conected to the trans. This is on the back of the block, you get those? How about the brackets near the oil pan?
the rear tranny mount, got those. the mount just flaps around.
its for a d16y8 motor and tranny(both stock).
i counted 5 bolts that i was able to take off from the top, but only 2 from the underside. i'm certain that im missin one but dont know where it is... i wish i had a camera.
i'll go outside again and make sure.
okay, i found another screw right next to the rear tranny mount.... that makes 8 bolts altogether. i think that might be it.. back to work i go.
thanks by the way.
thanks by the way.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MiMiK »</TD></TR><TR><TD CLASS="quote">hooray, that screw did it
yup, the starter's already off
now i gotta call up my buddy eddie to help me finish the job. thanks
</TD></TR></TABLE>Yeah when I do it if I forget anything it's those braces or **** even the inspection cover sometimes..
