So i got this b16a2 from a junkyard (need help first engine)
hello everybody.
so i just came back from the junkyard with this b16a2.
i dont know its condition so im gonna overhaule it. (not my self/in a shop)
this is my first engine that i buy so be delicat with me
please take a look in the picturs and tell me what are the components that are missing on this engine.
here is a list of the things that i know thats missing:
-DIZZY
-alternator
-throttle cable
-full engine wiring (the idiots just cut the wiring )
-engine pully.
now its your turn.... tell me if you see anything missing.
best regards moshik galimidi
p.s.
a day after i got the engine the guy from the junk yard called me and said he found the flywheel and the cluch... so i went over to take it....
are these any good?? is it of a b16?
Modified by RACEPAK at 11:29 AM 7/8/2005
-DIZZY
-alternator
-throttle cable
-engine pully.
p.s.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RACEPAK »</TD></TR><TR><TD CLASS="quote">
i think something is wrong with the motor mount bolts, they look bent
how much did you pay, i hope you didnt pay too much cuz this thing is going to nickel and dime you to death
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AdamQ3B85 »</TD></TR><TR><TD CLASS="quote">Tranny?
Axles?
im currently just collecting parts to complete the engine, not the instasllation/swap process.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jonas99 »</TD></TR><TR><TD CLASS="quote">Wow, great find. How much did you pay?</TD></TR></TABLE>
$630
or
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by built562 »</TD></TR><TR><TD CLASS="quote">
yeah i know that one of the bolts is bent.... but i think i can use a bolt from a D-serise.
Axles?
</TD></TR></TABLE>im currently just collecting parts to complete the engine, not the instasllation/swap process.
$630
or
???<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by built562 »</TD></TR><TR><TD CLASS="quote">
Yeah, obviously your missing tranny and axles
and if i were you i would take advantage in
installing a racing clutch while its open
your missing you distributor and your linkage
unless i missed seeing this on your pictures
but every thing else looks clean i dont know if
your wiring harness is to chewed up to re-use
though but other wise its a good start i Just
got B16 A2 AS WELL SHE RUNS GOOD .
GOOD LUCK ON THIS PROJECT. WHAT CAR IS THIS FOR?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 93ejay1 »</TD></TR><TR><TD CLASS="quote">630 for a b16 shortblock with rust and cut wires? eh u could have gotten it cheaper and in better condition but hey what do i care</TD></TR></TABLE>
thats because u live in the us and have planty of them...
i live in israel..... we have maby 10 B-serise engines running around here..... so for me it was cheap.
since hte motor is out alrdy
take out the head and check all the pistons and replace the head gasket and headbolts while u at it
shortblock = complete block... no head or IM
longblock = block and head, im, basically everything but tranny
any idea how many miles are on this motor? considering hmotorsonline sells 92-95 (and u have a 94) b16a longblocks for 900+shipping and "average" 25k miles and come with a few extra parts then what you have now i'd say it wasnt a bad deal considering there arent many Bs where youre at. good luck with it
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HATCHingMN »</TD></TR><TR><TD CLASS="quote">have fun looking for other parts
thanks for beeing so supportive. [NOT]
anyway.....
so is it obd1 or obd0?
also i have a few IM questions....
take a look....
-is that line suppost to go to the external map senor ?
what suppose to be bolted down here under the TB?
Modified by RACEPAK at 9:25 AM 7/9/2005
</TD></TR></TABLE>thanks for beeing so supportive. [NOT]
anyway.....
take a look....
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CTRwannaB »</TD></TR><TR><TD CLASS="quote">not sure but in one of the top pixs i think your TPS is broken :/</TD></TR></TABLE>
i know its broken but its still usable....
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RACEPAK »</TD></TR><TR><TD CLASS="quote">what suppose to be bolted down here under the TB?</TD></TR></TABLE>
I think its the fast idle but i might be wrong.Before its ready to go in make sure you do all the easy stuff like timing belt and waterpump
anyway.....
take a look....
Modified by RACEPAK at 9:25 AM 7/9/2005</TD></TR></TABLE>
that line on top of TB goes to the charcol canister, and by looks of it that TB is set up to use a TB mounted map, you can see to screw holes and a hole for the map tube/tip to sit in.
good luck
anyway.....
take a look....
good luck
