Coolant in the passenger compartment
Old Jul 8, 2005 | 09:35 AM
Stage587's Avatar
Default Coolant in the passenger compartment
I have a 92 prelude Si that is leaking coolant in to the passenger compartment on the passenger side. I'm not sure what the problem is, but i can tell it is serious. Any help on this matter will be appreciated.
Thanks, Jake
Old Jul 8, 2005 | 09:40 AM
95PreludeSi's Avatar
Default Re: Coolant in the passenger compartment (Stage587)
You sure it's cooland and not just water?
If it is coolant I would guess the heater core?
2lude4u's Avatar
The Heater Core itself may be leaking.
Look in your engine compartment and observe where the two hoses attach to the firewall (one comes off your block above the oil filter, the other from underneath the dizzy). Then get inside your car and see if the leak seems to be in the same vicinity, basically behind your center console. If it is the Heater Core, you're going to need to remove a fair amount of stuff in order to get to it. I haven't pulled one out yet, but will soon, so I can't go into much more detail.
Old Jul 9, 2005 | 09:34 PM
PrettyLude's Avatar
ccolant-heater core
water-evaporator core
LGxGirL
Nov 26, 2012 10:58 AM
phantomgreyhatch09
Sep 19, 2009 01:45 AM
Soda Popinski
Nov 7, 2005 12:39 PM
eternity0114
May 10, 2004 02:27 PM
