about exedy clutch and flywheel
Old Jul 8, 2005 | 06:34 AM
freshtyper's Avatar
Default about exedy clutch and flywheel
i just got ax exedy stage 2 clutch and exedy 9 pound flywheel installed into my 1998 champ type r. it has a jdm type r motor in it. now aftewr the installation everyttime i push the clutch in it makes a wierd sound. like cha cha cha cha, and it sound like a bearing and the flywheel keep on spinning. is that normal because the flywheel is so light. thanks
Old Jul 8, 2005 | 09:05 AM
92TypeR's Avatar
FSAE
Default Re: about exedy clutch and flywheel (freshtyper)
Its called cha cha cha chatter.
Its normal for light aluminum flywheels and light clutch discs to chatter.
Old Jul 8, 2005 | 09:26 AM
Eva01's Avatar
Default Re: about exedy clutch and flywheel (92TypeR)
The poster stated that this is when he pushes in the clutch it makes a noise. Clutch chatter occurs when engaging the clutch...I would recommend adjusting the clutch pedal and see if that remedies the noise. Check here https://honda-tech.com/zerothread?id=488573 or a Helms.
Old Jul 8, 2005 | 01:54 PM
Sehc Tib Alli Zerif!!!!!'s Avatar
cool guy name
Default Re: about exedy clutch and flywheel (Eva01)
My friend had this problem, it ended up being the star bolts that hold the flywheel on where extremely loose and rubbing.
Old Jul 8, 2005 | 02:42 PM
Circuit Star-29's Avatar
Default Re: about exedy clutch and flywheel (walker111)
This is a common issue w/ exedy clutches (Not mine, however). The bearing gets pushed too far into the diaphragm. You'll need to adjust your Clutch Master cylinder.
Old Jul 8, 2005 | 03:59 PM
Kenso's Avatar
HT White Ops
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by C-speed Ricer &raquo;</TD></TR><TR><TD CLASS="quote">This is a common issue w/ exedy clutches (Not mine, however). The bearing gets pushed too far into the diaphragm. You'll need to adjust your Clutch Master cylinder. </TD></TR></TABLE>
Exactly. Had this issue with my Exedy clutch a few years ago and adjusted the clutch master cylinder pushrod to correct it.
dannysolis92005
Jul 21, 2009 09:43 AM
beandip
Nov 23, 2003 11:31 AM
iwhichisme
Feb 28, 2002 04:42 PM
nugget8000
Aug 30, 2001 03:21 PM
