ECU Code 43 What Do I Fix???
I have a 92 Si Hatch with an h22a4 swapped into it right now its throwing a troubled code 43, which is Fuel Supply System, is that my fuel pump? injectors? or what? what do I need to fix? it sputters an shuts of alot an when the code is on VTEC doesn't engage, its also throw a Map Sensor code to
a Code 43 also means a possible h02 sensor problem. Most people replace that then the code 43 goes away. The only problem is that part is $$$ from the dealership.
James
James
