Road Racing / Autocross & Time Attack Road Racing / AUTOX, HPDE, Time Attack
Harness: Pull up or down
Old Jul 7, 2005 | 09:36 PM
.Thomas's Avatar
Default Harness: Pull up or down
can someone please explain the difference to me between a pull up style and a pull down, because i was looking at the G force belts 5 point, and i dont know which ones i need/want. thanks, sorry for super noob question.
Tommy
Old Jul 7, 2005 | 09:53 PM
D.CACO's Avatar
Default Re: Harness: Pull up or down (flatblkCR-X)
It refers to how you pull the straps to tighten. With a pull-down lap belt, the driver would pull the ends of the straps AWAY, whereas a pull-up lap belt the driver would pull the straps TOWARD himself. Hope that makes sense...
Old Jul 7, 2005 | 09:55 PM
.Thomas's Avatar
Default Re: Harness: Pull up or down (D.CACO)
ahh, which do most people preferr, also is there anything elese different, anyone stronger then the other?
Old Jul 7, 2005 | 09:57 PM
YeahRight!'s Avatar
with the pull down, gravity works to your advantage
Old Jul 7, 2005 | 10:02 PM
.Thomas's Avatar
Default Re: Harness: Pull up or down (YeahRight!)
i think the pull down would be easier, any big deal i need to know?
Old Jul 7, 2005 | 10:06 PM
SioneSi's Avatar
for the lap belts you'll more likely have more room to pull the straps up than down since it wont interfere with the race seat.
Old Jul 7, 2005 | 10:07 PM
rotten's Avatar
Get Pull Up.
I don't even know why they make pull down. The problem with pull down is that in order to tighten them you're actually pulling down into the seat, and if you're using racing seats there isn't anywhere to pull. Makes it really hard to tighten. Pulling up is easy, there is a bunch of space in which to pull.
If you want pull downs, get pull ups and we'll trade lap belts!
-k (who wishes he bought pull ups)
Old Jul 7, 2005 | 10:54 PM
WWDTrackRacer's Avatar
New User
Default Pull ups
Better on the lap as said before, you can get them tighter and centered easier.
Also on the shoulders, I believe pullups are better for the Isaac.
Old Jul 8, 2005 | 03:45 AM
jc836's Avatar
Our lap belts are Simpson Pull-Up. The shoulder harness is Pull-Down. Thesetup works best for me with the Spraco REV seat. There is technically NO difference in the integrity or strength of the assembly in either format (pull-up or pull-down). You will find that the standard for the harness is almost always pull-down, btw. Don't forget to properly adjust the anti-sub belt or you will find the lap belts being drawn up too high when you pull the harness tight.
Old Jul 8, 2005 | 04:50 AM
iggyracer's Avatar
Default Re: Harness: Pull up or down (jc836)
All shoulders are "pull down". I have never seen a pull up shoulder. pull downs work for alot of racers applications. Most often in production cars, or smaller cabin openwheel cars pullups are better simply because of the difference in tightening direction. Either system works as designed. If this is going into a production turned racecar, i would highly reccomend pull up belts in the new polyester webbing.
Old Jul 8, 2005 | 05:30 AM
Mugenlude's Avatar
I also aggree, pull-up belts.
Old Jul 8, 2005 | 05:53 AM
hbennett76's Avatar
There are probably more pull-down sets sold than anything else. The easiest way to describe the difference between pull-down and pull-up lap belts. Pull-up laps are tightened by pulling toward the buckle. Pull-downs are tightened by pulling away from the buckle. It depends on how they are mounted on whether or not tightening interferes with the seat. G-Force harnesses do not have the mounting hardware sewn in so this can be adjusted also.
Whether or not you should use pull-ups or not depends on personal preference and type of car. If you have a formula or car with an extensive full cage, pull-ups may be a better choice, especially in a formula car where you may have a crew member tightening your harness. In just about anything else, pull-downs may work just fine. Then it just gets down to personal preference. Some people believe they can get the lap belts tighter with pull-ups. It's also easier to just grab the end of the belt and give it another tug when on track. The only drawback is that you have the loose ends in your lap.
As far as I know, all shoulder straps are pull-down.
Howard Bennett
Racer Wholesale
Old Jul 8, 2005 | 06:20 AM
krshultz's Avatar
I guess I'll be the voice of dissent again. For me, I've never liked pull-up lap belts. Seems like they're impossible to loosen. Maybe there's a trick that I just don't get.
Old Jul 8, 2005 | 06:22 AM
TeamSlowdotOrg's Avatar
Default Re: Harness: Pull up or down (hbennett76)
My belts are pull-down and I've had no trouble getting them tight. I'd prefer pull-ups but the price was right on my set.
Modified by TeamSlowdotOrg at 9:26 AM 7/8/2005
Old Jul 8, 2005 | 06:44 AM
iggyracer's Avatar
Default Re: Harness: Pull up or down (TeamSlowdotOrg)
this is off topic but is that a diaper?
Old Jul 8, 2005 | 07:59 AM
CRX Toad's Avatar
Default Re: Harness: Pull up or down (iggyracer)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by iggyracer &raquo;</TD></TR><TR><TD CLASS="quote">this is off topic but is that a diaper?</TD></TR></TABLE>
It's a Pull Up...he's a big kid now! (cue cheesy music)
Old Jul 8, 2005 | 08:27 AM
Evan55's Avatar
Default Re: Harness: Pull up or down (CRX Toad)
Up
Old Jul 8, 2005 | 09:43 AM
bimmerboodle's Avatar
Default Re: Harness: Pull up or down (elgorey)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by elgorey &raquo;</TD></TR><TR><TD CLASS="quote">Up
HOT!!
Old Jul 8, 2005 | 10:57 AM
ralphie14's Avatar
Default Re: Harness: Pull up or down (bimmerboodle)
How much shipped to 68522!
blackdc5
12
Nov 25, 2007 07:24 AM
JeffS
Apr 13, 2005 02:17 PM
Lo-Buck EF
Feb 13, 2003 12:34 PM
Dan GSR
18
Nov 7, 2002 09:05 PM
uNF$@#!
Jun 27, 2002 10:25 AM
