Just put Uber in, Now my tach is goin crazy
Old Jul 7, 2005 | 08:57 PM
2000integrals's Avatar
Default Just put Uber in, Now my tach is goin crazy
So i just installed my uberdata ecu into my 2000 integra ls (using a obd conversion harness) Im only running I/E right now, so im just using the stock ls maps. After hooking everything up, car started up and ran like a dream first shot, no cel's went off or anything, but when i revved past 5k the tach would stop responding and drop down and then rise back up and just go all over the place, but the engine was still responding and acting and revving fine. So i switched back over to the original ecu and the tach was fine. WTF? Someone have an answer for me, PLEASE!
Devin
Old Jul 8, 2005 | 10:57 AM
Default Re: Just put Uber in, Now my tach is goin crazy (2000integrals)
Someone suggest something, PLEASE
Old Jul 8, 2005 | 11:49 AM
Flexin_B18's Avatar
was it a DIY project?
Old Jul 8, 2005 | 12:37 PM
khmboostedeh2's Avatar
what version uberdata are you using?
Old Jul 8, 2005 | 06:40 PM
i purchased the ecu chipped and ready to go from a reputable guy on HMT, then purchased an obd2b-obd1 conversion harness offline, hooked it all up and turned it on. Like i said, i ran around with it all day today and it ran like a champ, nothing out of the ordinary, the only thing weird is the damn tach any time i rev over 5500 rpms. Im using 1.7
Old Jul 8, 2005 | 06:46 PM
IntegraType-R's Avatar
Default Re: (2000integrals)
ecu probably turn it over on the back and make sure there's no ..metel pieces touching other parts of the motherboard or other terminals on the back of the chip where its placed.. if it is.. just take a boxcutter or knife and scrap it off you wont hurt the motherboard.. however if there's nothing touching its probably just your tach going bad..
Old Jul 9, 2005 | 12:14 PM
yee SERIOUS's Avatar
what ecu are you using? and why are you running uber?
Old Jul 9, 2005 | 04:34 PM
I'm using a P06 obd1, and i'm running uber so i dont have to spend crazy $$$ on hondata. Im boosting my car as soon as i get this ecu mess all figured out. I've got all parts other than the ecu, but since i got it in, i want to get it up and running nicely before i go installing my kit.
Old Jul 20, 2005 | 04:03 PM
Benbuilt4u's Avatar
im having the exact same problem in a 00 GSR. but i have a JDM p72 obd1 ecu.
Old Jul 20, 2005 | 05:36 PM
Benbuilt4u's Avatar
Default Re: (Benbuilt4u)
someone must have had this problem?
Old Jul 20, 2005 | 06:35 PM
Trance minister's Avatar
Yup, my 2000 LS has the same problem running a P75 and Uber. I'm curious to know if the OBD2 electronics in the distributor are the same as the OBD1 versions. I know they can be swapped etc., but there's got to be a good reason for it. I've never noticed this problem on pre OBD2 vehichles.
Old Jul 21, 2005 | 04:22 AM
Benbuilt4u's Avatar
Default Re: (Trance minister)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Trance minister &raquo;</TD></TR><TR><TD CLASS="quote">Yup, my 2000 LS has the same problem running a P75 and Uber. I'm curious to know if the OBD2 electronics in the distributor are the same as the OBD1 versions. I know they can be swapped etc., but there's got to be a good reason for it. I've never noticed this problem on pre OBD2 vehichles. </TD></TR></TABLE>
mine has the OBD2 dizzy but its JDM and has a larger then USDM cap
Old Jul 21, 2005 | 06:45 PM
Benbuilt4u's Avatar
bump
Old Jul 21, 2005 | 07:22 PM
boosted k20's Avatar
im run n uberdata in my 97 (OBD2) integra LS and i have NO problems at all with it. it will run fine with OBD2 cars with OBD2 dizzys. if i were u i would borrow a friends chipped ecu and put the uber chip in it and see if the problem still happens. if it doesnt, then send back the ecu to whom u buaght it from and get it replaced
Old Jul 23, 2005 | 05:04 PM
Benbuilt4u's Avatar
Default Re: (boosted k20)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by boosted k20 &raquo;</TD></TR><TR><TD CLASS="quote">im run n uberdata in my 97 (OBD2) integra LS and i have NO problems at all with it. it will run fine with OBD2 cars with OBD2 dizzys. if i were u i would borrow a friends chipped ecu and put the uber chip in it and see if the problem still happens. if it doesnt, then send back the ecu to whom u buaght it from and get it replaced</TD></TR></TABLE>
i dont think thats the problem since mine is a stock JDM ecu
Old Jul 23, 2005 | 07:45 PM
Benbuilt4u's Avatar
bump
Old Jul 23, 2005 | 07:51 PM
AllMotorDan's Avatar
hmm...i just got a p06 and im waiting for my uberdata to come in so i can chip the ecu. Hopefully it works
msweett
Apr 6, 2012 01:51 PM
HondaMechanic24
Nov 13, 2009 06:48 PM
JDM turbo DC
Oct 27, 2005 02:13 PM
Team 4
Dec 30, 2003 10:00 PM
TRuST
May 7, 2002 11:24 AM
