No cel at all (tried different ecu)
Hey guys i'm not getting a CEL at all, even for the first couple of seconds when it's supposed to. I'm not exactly sure when it started doing this but it wasn't too long ago because it was working less than a couple weeks ago.
It's a d16z6 stock on a virgin p28. I tried my friends virgin p28 and still same results. The car starts sometimes though but has a lot of trouble.
someone suggested that. At the moment i'm waiting for a friend to call me so i can buy his cluster. Mine is all messed up anways.
thanks for the reply!
Does anyone know any other possible causes? How likely is it that there is some sort of an electrical issue, even with it working fine just 2 weeks ago?
it could be the ECU or wiring, but I highly doubt it if you havn't changed anything.
since it doesn't turn on for the bulb check when you first switch on the ignition I'm betting it's the bulb.
arrocha87
20
May 13, 2009 03:46 PM
rasinhell
Jul 11, 2005 07:48 AM
