Heater Knob problem...
Old Jul 7, 2005 | 07:44 PM
1992AccordEX's Avatar
Default Heater **** problem...
Hi all, i own a 1992 honda accord EX and just recently my heater **** broke, i bought a new one online and for some reason it doesnt want to clip in. Has anyone else had the same problem, i hope something inside isnt broken!!
Thanks
-1992AccordEX
Old Jul 8, 2005 | 07:50 AM
SpeedFreak77's Avatar
Default Re: Heater **** problem... (1992AccordEX)
Check to see if your new one has a metal clip inside if not try to find the one that was in the one that broke and insert it into the new one.
Old Aug 15, 2005 | 10:17 PM
Default Re: Heater **** problem... (SpeedFreak77)
Time to bring this thread back to the top...I dont have a metal pin on the inside where the **** goes, where do i find a replacement pin...
I hear you have to pull apart the dash or something to get the pin in...or can i just snap it in?
Also is this something i could do EASILY by myself or can i bring it to someplace? i want to get this fixed now b4 the winter comes and i cant turn on the heat : /
Thanks
-1992AccordEX
Old Aug 17, 2005 | 07:11 PM
BLKFLSH's Avatar
Did you try switching it with the other ****. (fan control) aren't they the same?
Old Aug 17, 2005 | 07:23 PM
sauceja's Avatar
A pin of that size shouldn't cost but maybe a couple bucks from a dealership. Even the ***** aren't that expensive.
You should call your local H store and ask parts. It doesn't hurt to get a price.
Old Aug 17, 2005 | 08:22 PM
starchland's Avatar
Default Re: Heater **** problem... (sauceja)
when that happened to me i just glued it on.
Old Aug 17, 2005 | 11:47 PM
CB7VTEC's Avatar
Dunno if you checked up on you last thread, (https://honda-tech.com/zerothread?id=1331796) but the same info applies whether you are talking about the fan speed **** or the temp ****.
Yes, unfortunately something inside is broken. See item 11 or 13 below:
So, obviously the **** resembles a female type fitting. If the post, pin, male part, whatever you want to call it (that you push the **** onto) inside the fan switch or heater control **** is broken or missing, it is only replaceable by completely removing item 12 below:
and also items 1 and 4 below:
This is a time consuming but easy to do job. I'd hate for you to have to pay so much for labor for such a relatively cheap part.
Again, I hope this helps
Old Aug 18, 2005 | 10:33 PM
Default Re: Heater **** problem... (CB7VTEC)
wow that is quite the diagram...im not sure if i could do a job like that...although i dont wanna pay someone a lot to do it either...how much does it generally cost? i need to get this fixed b4 the winter hits or im gunna freeze my *** off!!! ROFL
Thanks for your help guys!
Old Aug 19, 2005 | 09:53 AM
Diego Dangers.'s Avatar
Default Re: Heater **** problem... (starchland)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by starchland &raquo;</TD></TR><TR><TD CLASS="quote">when that happened to me i just glued it on.</TD></TR></TABLE>
i did that, haha. but I used gorilla glue and it seaped out. now I am going on with surgery to fix that.
Old Aug 19, 2005 | 10:39 AM
amckee's Avatar
If you can't afford to fix it you can always move the bellcrank by hand before you start driving. It is white and is located on the right hand side of the console all the way toward the firewall about where the console meets the carpet. You cant reach it while driving but is better than freezing.
neli_nael
Jan 30, 2009 02:55 PM
greenzchatch
Jan 16, 2009 10:26 PM
dbbyleo
May 24, 2007 08:39 AM
Swanny0213
Audio / Security / Video
Dec 20, 2006 02:12 PM
ROCsFinest
Sep 29, 2005 09:14 AM
