grindin goin into 3rd
Old Jul 7, 2005 | 05:38 PM
hatchy54's Avatar
Default grindin goin into 3rd
i jus got a b16 w/ a stage 3 clutch put in my car and the motor only has 25000 miles on it and whenever im at like a high rpm switchin into 3rd it grinds but if do it like real slow like granny shiftin it doesnt...what could be the problem???
Old Jul 7, 2005 | 05:40 PM
shyboi4u's Avatar
Default Re: grindin goin into 3rd (hatchy54)
sounds like ur synchro are goin out
Old Jul 7, 2005 | 05:51 PM
skunkwhat's Avatar
what kind of fluid do you have in the trans?
did you just have the clutch installed or did it come with the swap?
Old Jul 7, 2005 | 05:54 PM
Setsuna F Seiei's Avatar
Honda-Tech Platinum Member
Default Re: grindin goin into 3rd (shyboi4u)
On your next tranny fluid change, examine the fluid or if you have a magnetic drain bolt, check for bits, chunks, filings of metal. Grey-ish filings-gears, bronze/copper-syncro, and shiny silver-bearings. People would suggest using a new tranny fluid with friction modifiers in it but it would only remedy the prob temporarily, might as well open the trans if you're able to and check yourself
Old Jul 7, 2005 | 07:09 PM
oem_dc2's Avatar
Default Re: grindin goin into 3rd (BrokeAssPinoy)
maybe the shiftlinkage is bent. any slight bend will cause this
Old Jul 7, 2005 | 07:14 PM
moto1320's Avatar
Default Re: grindin goin into 3rd (BoostedTeggy)
check your clutch hydraulics as well. if they aren't up to snuff it can grind.
civic99585
Jan 27, 2009 11:14 PM
phanatic
Aug 25, 2006 03:31 PM
fanta!
12
Dec 30, 2005 06:59 AM
WingDC2R
Dec 11, 2005 08:21 PM
andrewasf77
Jun 19, 2003 07:32 PM
