B16 thinks oil is beer!
Old Jul 7, 2005 | 04:09 PM
TheIceMan's Avatar
Default B16 thinks oil is beer!
whats up fellas....juss swapped my EK wit a JDM b16.....so anyway its been about 30 solid days ive had the car...i must admit (I wont lie) i frequently rev high and hit vtec very often....well i noticed on the 4th of july that my dipstic read the oil was low...(@ the first notch on dipstick)...WOW...and now today (july 7)...i noticed i had almost no oil!!!!!i immediately fed her 2 quarts of mobil 5w30....(originally 10w30). im not gonna run my car like i was doing...but is this normal...i have NO leaks and there are no signs of any oil near my sparkplugs...IS 2 quarts enough???according to the dipstick it is...but how many quarts could a b16 fit when its dry???noticed my antifreeze was a little low as well...Whats the deal fellas???is it the beating on the car thats burning up the oil...or could it be something else???
Old Jul 7, 2005 | 04:10 PM
Deemeetree's Avatar
Electrician
Burning a LITTLE oil due to VTEC crossover is normal. But, losing quarts within weeks is not.
Do you have any smoke coming out of your tailpipe? Was the engine rebuilt in any way? How many miles are on the engine?
Fellow Queens citizen.
Old Jul 7, 2005 | 04:16 PM
BlueIntegraBoy's Avatar
Default Re: B16 thinks oil is beer! (SigleyEK)
My valve stem seals are out on my B18C. I go through a quart of oil every 3 weeks or 1000 miles. I check my spark plugs and there isn't any signs of oil, but my tail pipe says otherwise.
Old Jul 7, 2005 | 04:17 PM
JDM-97CX's Avatar
Default Re: (Deemeetree)
So you are losing oil and antifreeze? Do a leak down test, I think there is a chance your head gasket may be bad.
TheIceMan's Avatar
well i juss got the motor....stock jdm b16 with 20-50K on it....come to think of it at very high rpm's i did see some white smoke in my rearview???these engines are guaranteed to be leakdown tested...compression tests..etc.....so i dunno whats going on
Old Jul 7, 2005 | 04:24 PM
TheIceMan's Avatar
Default Re: (SigleyEK)
any help would be appreciated....supposedly these motors are guaranteed...(atleast for major **** like that). Any thing i should look for....i would appreciate if someone could gimme a couple troubleshooting methods......cause i know that this is far from normal....what should i look for in my tailpipe??underhood???i am positive that i dont have an oil leak
Old Jul 7, 2005 | 04:29 PM
Deemeetree's Avatar
Electrician
You might not have an oil leak, but you could be burning oil. Actually, it's probably positive that you are burning oil. Just to let you know, there is no way it has 20k-50k miles on it. Most are definitely past the 60k range.
Remove you spark plugs and check the condition of them.
Old Jul 7, 2005 | 04:47 PM
Archidictus's Avatar
Unceasing Measure
And until you figure out why you're burning oil, stop using Mobil 1. In fact, after you figure it out, continue to use a basic, cheap motor oil and change it every 3.000 miles and you'll be just as well off as with the synthetic but with an extra $20 in your pocket.
TheIceMan's Avatar
so i guess the motor companies bluntly lie about how many miles are on their engines...
Old Jul 7, 2005 | 05:06 PM
Sijray21's Avatar
is it just me or am i seeing a lot of these threads with the b16's lately?
it's happening to me as well, run a compression and a leak down test. If there's no visible leak it's probably bad rings or valve stem seals
hondacrx2
Oct 11, 2007 03:40 PM
teler86
Sep 21, 2006 07:34 AM
Suck my DX
Jun 12, 2005 02:09 PM
