Head gasket type s...
I am running 11:1 compression in my h22a1: type s pistons, I was wondering and there for searching, if there are any manufactures that provide a thinner headgasket, to up the compression a bit more, and still be on the safe side....Im already tuned, but am using cams....thanks
If you are going to go through all the trouble to pull the head then you might as well go with flat faced valves and mill the head .020" that would probably get you into the 12's for compression... Othewrwise you can pull the middle layer out of the OEM HG and it will increase your compression marginally.
Pirate
Pirate
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by [ S7H »</TD></TR><TR><TD CLASS="quote">Is the stock bore size for 97-01 Prelude 87mm?
What about HG thickness?
ANYONE?
stock bore is 87mm, compressed gasket thickness is .026"
ANYONE?
were can I get some flat faced valves, and do I need a valve job with them?
Should I also change out my retainers, and keepers, mine as well change the springs......***** adding up.....
thats why I just wanted to get a head gasket....so point me in the right direction please
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by [ S7H »</TD></TR><TR><TD CLASS="quote">]compress gasket thickness = 0.26" = OEM thickness?
Stock bore is 87mm? any advantages or having oversize bore at all?</TD></TR></TABLE>
Displacement...
But you need to sleeve your block for that... Unless you only want .25mm extra... Do some searches on overboring H-Series and FRM....
Displacement...
wtf this thread is not being jacked or anything...... im talking about headgasket for compression......stock bore stock valves....
strickly headgaskets for compression
Ivan_JDM_hatch
12
Jul 13, 2007 06:44 PM
