Accord V-tech Head Swap
Old Jul 7, 2005 | 03:38 PM
mo power's Avatar
Default Accord V-tech Head Swap
Is it possible to swap a sohc v-tech head off of a 1999-up accord to a 1990-1992 accord?
Old Jul 7, 2005 | 05:42 PM
93b16CivicSi's Avatar
Default Re: Accord V-tech Head Swap (mo power)
can somebody tell this guy how to spell VTEC!!!
Old Jul 7, 2005 | 07:11 PM
slomofo's Avatar
GDD Member
Yes, it's possible. Browse the civic forums and read up on mini-me swaps. Same process, bigger head.
Edit: You'll need to use the injectors that came stock in the car you're swapping into, and if it's going into a 92 accord, you need to use the 94-95 EX ECU, if in a 90-91 Accord, use a WOT or RPM activated VTEC switch with the stock ECU.
Old Jul 8, 2005 | 12:21 PM
IHateJDM's Avatar
Default Re: (slomofo)
the 90-92 vtech's were 15 channel, and the 99 up vtech's are either 900 mhz or 2.4 ghz, so I'm predicting problems while swapping the antennas.
Old Jul 8, 2005 | 01:31 PM
RotiEatter's Avatar
Ditto
Default Re: (IHateJDM)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by IHateJDM &raquo;</TD></TR><TR><TD CLASS="quote">the 90-92 vtech's were 15 channel, and the 99 up vtech's are either 900 mhz or 2.4 ghz, so I'm predicting problems while swapping the antennas.</TD></TR></TABLE>
Hasport mounts are great here. HCP mounts will work, but they kinda place the antenna a little lower than I would like it.
C_Rock77
Feb 4, 2009 08:19 PM
helpmeplease
Mar 29, 2008 05:17 PM
JDMAccordGuy
Jan 23, 2007 07:26 PM
