Road Racing / Autocross & Time Attack Road Racing / AUTOX, HPDE, Time Attack
I like this DIY alignment rack
Old Jul 7, 2005 | 06:46 AM
Another Drew's Avatar
Default I like this DIY alignment rack
If I only had the space to store one of these
I saw this at a local shop. It looks quite easy and fast to setup. It's got height adjustable feet to level it. Just drive the car up on the ramp and onto the pads, slide the alignment rack around to center it under the car, and voila.
Old Jul 7, 2005 | 06:53 AM
moto27cm's Avatar
That appears to be a nice setup. Note the centerline string. Clever.
Old Jul 7, 2005 | 07:29 AM
Autoworks's Avatar
Default Re: (moto27cm)
I bet its a bitch to do an alignment sittin ground level
Old Jul 7, 2005 | 10:00 AM
Johnny Mac's Avatar
Default Re: (Autoworks)
That's a nice rig, and unfortunately it doesn't fold up. But, for an alignment shop that's okay since they don't need to move it anyway.
Old Jul 7, 2005 | 11:15 AM
.RJ's Avatar
.RJ
Default Re: I like this DIY alignment rack (Another Drew)
The problem with that is, you never really know if the car is lined up with the strings or not.
Old Jul 7, 2005 | 11:23 AM
Default Re: I like this DIY alignment rack (.RJ)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by .RJ &raquo;</TD></TR><TR><TD CLASS="quote">The problem with that is, you never really know if the car is lined up with the strings or not.</TD></TR></TABLE>
That's what the center string is for. You find the center line on your car and permanently mark it. Everytime you do an alignment, you drop a plumb line down from the marks and move the rack until the centerstring touches the plumbline.
Old Jul 7, 2005 | 11:29 AM
.RJ's Avatar
.RJ
Is that accurate to 1/32" though?
Old Jul 7, 2005 | 12:32 PM
&lt;shrug&gt; I'm not sure, but I can't imagine it being any less acurate than a jackstands/conduit setup.
Old Jul 7, 2005 | 12:51 PM
descartesfool's Avatar
Here is why I like my setup: You can drive the car in and out of garage with it attached and make sure the suspension is settled, drive it back on the scales and check again. Plus it is light, portable and storable, and very cheap. And yes, it is accurate and gives consistent, repeatable measurements, and you can leave it attached while you adjust both camber and toe, and unlike jack stands and conduits, you can't really knock it out of place.
https://honda-tech.com/zerothread?id=597192
PowerLeg
Suspension & Brakes
Sep 18, 2008 11:26 AM
vinuneuro
33
Jul 26, 2008 08:44 AM
MEDIEVIL
Oct 11, 2006 04:57 PM
parki59
Apr 25, 2006 03:37 PM
Thasty
Sep 17, 2003 03:33 PM
