Help, fuel pump
Old Feb 14, 2002 | 09:33 PM
justagsr's Avatar
Default Help, fuel pump
Just purchased 98 gsr and there is a high flow fuel pump installed. Problem: when the tank is half full it acts like the tank is empty and when I fill it up again it only takes about 6 gallons. I'm planning on dropping the tank to see what the problem is (figure I'll look in Chilton's or Haynes for that). Anyone have any suggestions?
Old Feb 14, 2002 | 10:04 PM
dustin's Avatar
Default Re: Help, fuel pump (CivicRacerGSR)
I would just pull the pump out (no need to remove the tank) and make sure the filter and lines are hooked up properly.
Dustin
Old Feb 14, 2002 | 10:48 PM
justagsr's Avatar
Default Re: Help, fuel pump (dustin)
Thanks, I'll check that out tomorrow. Still referring to the Chilton's b/c I just got this car and not use to this engine. I'll be sure to tell you what I come up with. And don't worry, you'll be seeing plenty of questions since this car just needs little bit of T-L-C. Got it cheap though.
Owner:
97 Civic Ex
98 GSR-t
Old Feb 15, 2002 | 08:34 AM
racerxadam's Avatar
i've seen similar symptoms in cars that have large dents in the fuel tanks.
Old Feb 15, 2002 | 09:25 AM
John's Avatar
New User
Default Re: Help, fuel pump (racerxadam)
dent in the fuel tank... now that takes some talent...
sc0braj
Oct 4, 2008 02:15 PM
jerry454
Apr 21, 2008 10:35 PM
EKSedAndy
Nov 12, 2007 10:22 AM
PyroVTEC
Apr 10, 2002 10:02 PM
