Brakes acting up...
Old Jul 6, 2005 | 06:50 PM
LSVTEC 91 Civic's Avatar
Banned
Default Brakes acting up...
Ok, I started to notice this about a month ago, but the problem seems to be getting worse over time.
When I'm slowing down to a light, and I ease on the brake pedal to come to a slow stop, the brake pedal slowly makes it's way to the floor... and I come rolling to a stop. The brakes seem to work fine when I'm in gear and slowing down, seems like the pedal only goes to the floor when I idle to a stop.
Anybody else here fix a problem similiar to mine?
Old Jul 6, 2005 | 07:05 PM
shawn_crx's Avatar
Default Re: Brakes acting up... (LSVTEC 91 Civic)
bleed the brake.
possible leakage
bad MC/BB
Old Jul 6, 2005 | 07:41 PM
Banned
Default Re: Brakes acting up... (shawn_crx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by shawn_crx &raquo;</TD></TR><TR><TD CLASS="quote">bleed the brake.
possible leakage
bad MC/BB</TD></TR></TABLE>
I don't seem to be losing any brake fluid anywhere... Any way to test for a bad brake booster?
Old Jul 6, 2005 | 07:55 PM
drussell4801's Avatar
long standing rule of thumb is that if the pedal sinks to the floor, its leaking; externally or internally. Either the fluid is leaking out or its leaking in the master cylinder.
bad brake booster will cause excessive pedal effort.
Old Jul 6, 2005 | 07:59 PM
sanimalp's Avatar
$cat /dev/urandom
Default Re: Brakes acting up... (drussell4801)
yeah i had the same problem and i replaced the master cylinder. brakes work great now.
a way to check your brake booster is to turn your car on with your foot on the pedal with some pressure on it. when the car starts, you should feel the pedal sink a little bit. if it doesnt sink or stays the same, then youre booster needs to be rebuilt or replaced.
the problem you are describing though is deffinetly master cylinder whose seals have had it. another possible cause is loose bleeder screws or a hole in a brake line, but you would be seeing brake fluid leaking everywhere.
hteg12
Jul 18, 2013 05:13 PM
tazz29
Jul 9, 2008 10:52 AM
spintboy
17
Jan 3, 2008 08:49 AM
s10cky
17
Dec 20, 2006 07:19 PM
FourthGenHatch
15
Oct 5, 2002 07:53 PM
