speedometer cable
Old Jul 6, 2005 | 06:43 PM
LudeJdm's Avatar
Default speedometer cable
need help replacing speedometer cable...what tools...steps to take...any tips....basically how to??? 88 hatchback
Old Jul 6, 2005 | 09:36 PM
vegaskurt's Avatar
Default Re: speedometer cable (envysionHATCH)
did it break or is it making noises?
you can replace the inner wire in about 10 minutes. Disconnect the cable from the back of the speedometer. Then on the top back of the tranny, pull the boot around the cable, then use a needle nose plyer to pull the retaining clip off. The cable comes right out.
I had to re-grease mine a few months back.
Old Jul 7, 2005 | 08:05 PM
LudeJdm's Avatar
Default Re: speedometer cable (vegaskurt)
basically juss pull out the cable not many tools needed???
Old Jul 7, 2005 | 08:38 PM
vegaskurt's Avatar
phillips screw driver for the dash. needle nose for the retaining clip. Thats all I can think of. Probably make it really easy if you remove the intake hose/tube.
Old Jul 8, 2005 | 07:11 PM
LudeJdm's Avatar
do i need to jack up the car and put it up on jack stands???or can i do it from the top???i have a single cam motor...
Old Jul 8, 2005 | 07:23 PM
fkguitar's Avatar
I did this to mine on the ground in about 30 minutes (the first time takes a minute). Just take the dash off 2 screws in the back hidden under covers that a flathead screwdriver will help to pop off and then one screw under the hazard light and another in virtually the same place on the other side. Then once thats off look on the far right side of the cluster basically behind the speedo and the cable should be in a golden cap thing that clips into the cluster and then running I think through the firewall into the engine bay. Ok then in the engine bay I'd say about dead center on the firewall there should be a wire sticking out to the left a little. Follow that to the back of the tranny and pull back the rubber boot and then you can snap it off there with needlenose pliers. I hope that helps.
Old Jul 8, 2005 | 08:18 PM
LudeJdm's Avatar
Default Re: speedometer cable (fkguitar)
ok...i need help getting the new cable thru the firewall...i cant seem to get it thru....im going from the cluster side towards the engine...but can get the cable thru i dont know where the hole is....a picture would help....
Old Jul 9, 2005 | 10:46 AM
vegaskurt's Avatar
Disconnect it from the tranny first and run the new wire from the engine side to the dash. It should just slide through the stock sheath.
Old Jul 9, 2005 | 11:01 AM
LudeJdm's Avatar
aite got it thru the firewall...now need help on pluggin it in the tranny....what to do with the horseshoe shaped clip??? do i keep it in the boot and push the cable and boot down??? what to do how do i put the clip on????need help
Old Jul 10, 2005 | 02:33 PM
vegaskurt's Avatar
On the tranny where the cable goes in. You will feel a groove on the bottom of that thing, thats where the clip will snap into to hold the cable in place. Just push the cable into the tranny as far as it will go then get the clip into the groove. Then just put the dust cover back over it.
Old Jul 11, 2005 | 07:17 PM
LudeJdm's Avatar
aite i did it i installed the speedometer cable and everything...but how come im still getting code 17??? thats weird....my speedometer works..everything works how come im getting code 17 still???
Old Jul 11, 2005 | 07:29 PM
HiProfile's Avatar
You should reset your ecu. How? Disconnect the battery for a few minutes.
I finially got my d16z6 in my 4g4dr working, but the speedo wasn't working. I thought it didn't go in very well, this post reminded me of the clip VT@K!!
Old Jul 11, 2005 | 07:36 PM
LudeJdm's Avatar
Default Re: speedometer cable (HiProfile)
cant i juss pull the ecu fuse????
Old Jul 11, 2005 | 07:46 PM
LudeJdm's Avatar
how long do i take it out for???
Old Jul 12, 2005 | 04:56 PM
LudeJdm's Avatar
ok i resetted the ecu still gettin code 17 but everything else works...its an 88 civic hb w/d16z6 and chipped p28 ecu help please
norcal450
Jan 5, 2007 03:10 PM
philkehn
Nov 19, 2006 10:08 AM
2000dollarzcbs
Oct 1, 2006 01:18 PM
( o )( o )
Sep 1, 2005 09:03 PM
LD_EGSICK
Dec 4, 2002 12:00 PM
