Just bought An 89 4dr LXi What to tune first.
Old Jul 6, 2005 | 03:16 PM
mycrxsucks's Avatar
Default Just bought An 89 4dr LXi What to tune first.
Ok just got my 1989 LXi 5 speed and have a couple of questions like what motor does it have and what to tune first. Or what motor swaps could I do on the cheap. I want this car to be a sleeper. New to hondasBTW
Old Jul 6, 2005 | 08:10 PM
NAiL05's Avatar
Default Re: Just bought An 89 4dr LXi What to tune first. (mycrxsucks)
You got an A20A3 i think thats motor code or something like that. It would be bad *** if you could drop a frankenstein motor in there. You could do some basic bolt ons but i dont really know the tuning capabilities of an 89. Im sure there are some other people on here that are knowledgable to help you out.
Old Jul 6, 2005 | 08:14 PM
Vanilla Sky's Avatar
http://www.3geez.com is a HUGE help.
there's a good bit that can be done, but don't expect the raw numbers a b-series can put down.
Old Jul 6, 2005 | 09:10 PM
P_Adams's Avatar
Engine? 2.0Litre SOHC Non-Vtec Programable Fuel Injected. Engine's pretty much bulletproof stock. Turbo Kits, cat-backs and such are available, but you'll have to search for the traditional go-fast parts if you want to go that route.
The only weaknesses this generation (3rd) Honda demonstrates are in two areas.
1) Body corrosion around rear wheel wells.
2) Ball Joint / Suspension - non serviceable
I've owned two (88 & 89), and the '88 I still blast down country roads at 228,000 miles.
Keep it maintained and you'll have a blast!
P
Old Jul 6, 2005 | 09:49 PM
there aren't turbo kits for these cars. it's all custom if that's what you really want. they are iron block motors, though.
Old Jul 6, 2005 | 09:58 PM
2dr89AccordSE-i's Avatar
Default Re: (Vanilla Sky)
and the only catback available for our cars sucks. really no aftermarket support at all, but we have found that many parts from other cars can be used with minor modifications. 3geez.com, like he said
Old Jul 7, 2005 | 10:11 AM
James's Avatar
Default Re: (2dr89AccordSE-i)
basic routine maintenance like air filter, spark plugs, spark plug wires if needed, change oil, change tranny oil(?), change fuel filter, check belts and hoses for cracks, check coolant, check brakes, check tires, check fuses if any blown, check & fix leaks if any, check timing, try to replace timing belt if do not know when last change, and keep up with the maintenance and treat it like baby. it wil give you many good years of cheap transportation. also feel how clutch is working, if manual, to see if it enages smoothly while shifting and not slipping when up on a hill.
my 18 yrs old son has 89 accord lxi with 230k miles and he travels all over and very happy with the car. yet he is taking pretty good care of the car.
SwooziePB
Oct 19, 2014 11:41 PM
VTi_b0i
Jan 11, 2008 12:05 AM
mike84 CRX-GTL
18
Mar 18, 2006 09:20 AM
speedy94ex
16
Oct 3, 2005 11:51 AM
