obd-0 RHD jdm vs. LHD usdm engine harness - rhd conversion problems
Old Jul 6, 2005 | 10:19 AM
tegboi's Avatar
Default obd-0 RHD jdm vs. LHD usdm engine harness - rhd conversion problems
what are the real differences in it? i've been told that i specifically need the rhd obd-0 b16a harness in order for everything to work correctly.
the setup/wiring/engine
engine is a first gen b16a, and i think my buddy threw away the engine harness that came with it when i swapped the motor at his house..
jdm engine bay harness, jdm cabin harness, jdm dashboard/gauge cluster harness
usdm b18a1 stock engine harness, usdm rear section harness (tail lights & fuel pump i belive is all..)
so far, it has a crank but no start condition, there's fuel pressure, but no spark. i tested using the screwdriver in the wire near a ground method, and nada. also, the ecu is not blinking or anything, showing signs of power/startup, even when you turn the key to the on position.
but, when i checked with a test light from the power to ground on the ecu harness, it has power.. and i've also checked incase the ecu was bad, by using another ecu i have, but it did the same thing.
UniqueX707
Nov 24, 2014 11:33 AM
hannslebo
12
Jun 4, 2009 12:24 PM
Jimmii
Apr 9, 2009 06:54 PM
Kirk@SyndromeAuto
Dec 13, 2006 05:24 PM
94rs-turbo
Nov 11, 2005 06:57 PM
