jdm h22 timing/distributor instal help...
Old Jul 6, 2005 | 08:04 AM
turboH22Aakkord's Avatar
Default jdm h22 timing/distributor instal help...
well, i have a jdm h22a in a 92 accord... (im actually working on tunning it right now) never mind that though.... well, i was trying to get my basemap to work right when the dredded h22 distributor **** the bed on me... now i was just wondering if the distributor going bad may have messed up stuff in my head (how would i know if **** was damaged) and how do i install the new distrib to make sure its set at the proper timming (is that a mark or something?) thanks guys...
Old Jul 6, 2005 | 08:11 AM
v4lu3s's Avatar
RTFM
put the new distributor on and set it in the middle, and if you are **** use a timing light to set timing on it.
Old Jul 6, 2005 | 08:45 AM
Default Re: (v4lu3s)
kool, thats what i figured... now i was also told that the h22 timing was "different" with the h22... for example... you could turn the distributor all you want and not affect the timing... i guess what im asking is.. how do i adjust the timing on the h22? thanks again...
Old Jul 6, 2005 | 09:36 AM
pentaq's Avatar
Default Re: (turboH22Aakkord)
Actually it can damage the whole head when a distributor bearing stalls... Then it locks and your camshaft wants to spin Something will give up. Mostly camshaft. You can imagine the result
Old Jul 6, 2005 | 09:41 AM
Default Re: (pentaq)
oh boy.. haha.. i dont think it stalled though.. i think it just wore out ... it had the typical "red dust" in the cap but when i took the distrib out it would spin ok but you could hear it grinding... thanks for the info... does anyone else have any tips on timing this bitch? thanks...
Old Jul 6, 2005 | 09:45 AM
pentaq's Avatar
I gave you an answer and you give me yours here (if your nick is true) https://honda-tech.com/zerothread?id=1299282
Old Jul 6, 2005 | 10:04 AM
you've been PMed sir...
Old Jul 6, 2005 | 01:09 PM
v4lu3s's Avatar
RTFM
if you have an obd1 distrbutor you can adjust timing. if its ob2 then you cannot.
MastaFlyMason
Oct 2, 2016 02:53 PM
powerofdreams8
Sep 26, 2007 07:45 AM
badCRX
Feb 26, 2003 11:53 AM
accorracer
Feb 16, 2003 10:00 AM
