Removing axles for engine swap?
Old Jul 6, 2005 | 07:36 AM
NACvicSi's Avatar
Default Removing axles for engine swap?
Every write up I read says to remove the entire exle from the car to do the swap. Can't I just leave it connected to the wheel/fork/etc. and just pull it from tranny?
Old Jul 6, 2005 | 07:41 AM
EP3_05's Avatar
Default Re: Removing axles for engine swap? (NACvicSi)
The spindle and hub assembly keeps the axle firmly seated in the trans. So unless you unbolt the spindle so it can swing out of the way you will not be able to remove the axle from the transmission.
Old Jul 6, 2005 | 07:45 AM
NACvicSi's Avatar
Default Re: Removing axles for engine swap? (91civic)
Gotcha, thanks for the help. Looks like it will just be a good chance to get the rotors turned.
civic92vx
Jun 29, 2010 09:55 AM
sde780
Jul 8, 2009 10:51 AM
kinkyintegra
Jan 12, 2007 11:52 AM
Alexs S2K
12
Aug 14, 2006 12:46 PM
Passaudi1.8t
Jan 13, 2004 10:01 PM
