h-beams or i-beams rods?
Old Jul 5, 2005 | 09:57 PM
SoOHiGH's Avatar
Default h-beams or i-beams rods?
im doing some reasearch for a turbo setup im going to do and want to know which is better for 400-500whp.
i heard that a lot of stress is on the walls and that the i beams are better....
what you guys think?
Old Jul 6, 2005 | 12:35 AM
ChrisRicketts's Avatar
Default Re: h-beams or i-beams rods? (SoOHiGH)
i-beams are better........but get some manley rods, or pauter. manley rods are super strong rods, and they are priced pretty low compared to pauter.........more comparable to the i-beams.
i had h-beams in my 377whp h22, and the rod bolts broke causing total engine damage. this is not to say because the h-beams are bad..........i'm sure the i-beams probably even use the same bolts..........but if you're going to build an engine, you might as well spend a little extra here and there to save you any possible headaches in the long run. i'd say go with some manley or pauter (if you can afford it) rods, or at least the i-beams.
kolumbo69
49
Dec 19, 2007 05:42 PM
silverskateEF9
31
Oct 6, 2007 07:13 PM
b.d.racing
13
Dec 19, 2005 11:17 PM
cuin9sec
Jul 19, 2005 08:06 PM
