Small ammounts of rust?
Old Jul 5, 2005 | 09:42 PM
Voodooboy520's Avatar
Default Small ammounts of rust?
I got my CRX, nothing appeard to be major. Just a few spots on the underside of the hood, some rusted boltheads on the header. I just recently discovered the joyious spots in the spare tire well, and perticularly in the left corner. Nothing major here, but from the previous posts I assume grind and bondo\primer? Its a white car, and its the tire well, so it wont matter how it looks.
Just one other little question, I'm mounting the battary box in the trunk (very similar to how it was done on homemadeturbo.com), and I saw rust stains on the INSIDE of the chassis (screw has to go up through it). Is this gonna cause problems down the line? There is no way I can get to it.
Anyways, I'll shutup and let the pics talk.
Old Jul 5, 2005 | 09:53 PM
kim_2_da_chee's Avatar
Default Re: Small ammounts of rust? (Voodooboy520)
It doesn't look TOO bad...
I'd just scrape/sand the rust off, and spray some RustCheck or some kinda rust control undercoat over it.
You may have just seen "stains" on the chassis... it's hopefully not totally rusted through. If you can break pieces of your chassis off with taps of a hammer, then you're in trouble
Old Jul 5, 2005 | 10:15 PM
The chassis is totally fine, the stains were inside it, and its solid all the way through all around. I'm not concerned about that.
aalb1
Jun 30, 2009 09:55 PM
ctownintegra
Audio / Security / Video
11
Feb 22, 2005 03:30 PM
stormywaters
Mar 16, 2003 03:51 PM
Fuster_Cluck
70
Feb 28, 2003 08:29 PM
SlippylesKB
11
Feb 28, 2003 02:33 AM
