is building a d16a6 worth it?
Old Jul 5, 2005 | 09:26 PM
honcrx91si's Avatar
Default is building a d16a6 worth it?
i've been having trouble figureing out what i want to do. i want to build an all motor d16a6 with nippon zc pistons to raise compression i also want to bore it .20-.40, not sure which one, i would also eventually rebuild the a6 head or do a mini me swap. my other opinion is just getting a dohc zc. im kinda worried that i am going to be disappointed with the power i will make from the a6 for how much money it will cost to rebuild. i dont have a lot of money to throw around so i am trying to get the most for my money. if someone could give me some suggestion or opinions that would be great thanx
Old Jul 5, 2005 | 09:39 PM
ramirocka's Avatar
Default Re: is building a d16a6 worth it? (honcrx91si)
i don't recomment doing anything to your sohc. you should save your money and get a swap. even if you bore it out and you put some bolt ons; you probably wont even keep up compared to a crx with a B18...
Old Jul 5, 2005 | 09:50 PM
redED9Si's Avatar
Default Re: is building a d16a6 worth it? (ramirocka)
very wrong to say, I have see GSR's loose to SOHC! But B-series or K-series power built up will destroy a built sohc for sure... sorry to say but I would go b-series for sure if you were going to spend a **** load of money on a motor. B16a or b18a is a great place to start
repingjdm
Jan 19, 2011 01:50 PM
farmboy777
Jan 31, 2006 08:18 AM
Importracin43
May 10, 2005 11:01 AM
YBELEGL
35
Aug 30, 2004 04:11 PM
Sukebei Oni
Jan 9, 2003 12:28 AM
