help on D16A1 swap into 89 civic HB
I own a 89 civic HB and have the stock motor in it and I just bought a D16A1 engine from a junkyard. They only problem is the engine dont have a tranny w/it or a ecu.
Can I use the same tranny that's in my car? What type of ecu do I need to buy? Plus what else do I need to buy to get this engine running?
Any information will be helpful.
The stock 1.5 trans will work (4 or 5 speed). You will need the pm6 computer or equivalent (ZC computer would work the best.) Check these links out for more info, next time do a search first.
http://www.geocities.com/c_rexboy/mpfi.html
http://hondaswap.com/swap-arti...9557/
http://effinmotorworks.com/Effin_MPFI_swap.htm
remember use solder and shrink wrap
Modified by mntuner2 at 10:26 AM 8/9/2007
ejg398
Feb 13, 2006 06:10 AM
