short shifter
Old Jul 5, 2005 | 07:15 PM
egzo04's Avatar
Default short shifter
i have a 96 accord 4d ex if i order a short shifter adapter off ebay like this http://cgi.ebay.com/ebaymotors...33736 is this all i need? or what all do i need to make it a short shifter? thanks
Old Jul 5, 2005 | 09:08 PM
boostmyda's Avatar
Default Re: short shifter (egzo04)
when it says
"****All Short Shifters are ALL SALES FINAL."
that is generally not good..
i would go for a name brand ..
allthough i do not know any
usually ebay stuff like that is kinda cheap
Old Jul 5, 2005 | 11:33 PM
Andrew SIR's Avatar
PSPEC Tuning
http://www.pspectuning.com/index.php
or
Forbidden Motorsports
http://www.forbiddenmotorsports.com/
Old Jul 6, 2005 | 04:05 AM
egzo04's Avatar
Default Re: (Andrew SIR)
thank you
Old Jul 6, 2005 | 06:28 AM
TouringAccord's Avatar
H-T Order of Merit
Default Re: (egzo04)
like Andrew SIR posted. Those are the only true short shifters for the Accord and Prelude. Have heard many good things about them. The adapters you see on eBay and such have mixed reviews. I heard many people say they are notchy and some have said they work fine. If you go with an adapter, make sure research it to make sure it has good reviews first. But personally, if I still had my Accord I wouldn't even bother with an adapter and I would get the Pspec or Forbidden shifter. Search the Accord forum, you'll see other threads about these shifters as well.
Old Jun 11, 2007 | 08:48 PM
accord478's Avatar
isnt there pilot short shifter for accord ?
Old Jun 12, 2007 | 04:19 AM
H-T Order of Merit
Default Re: short shifter (accord478)
a quick google search tells me that is just an adapter. yes, there is one for Accords but I wouldn't waste money on an adapter, save up and get a PSPEC or Forbidden.
Old Jun 12, 2007 | 06:27 AM
FarinaMotorsports's Avatar
Default Re: short shifter (TouringAccord)
We tested some short-shift adapters on our Accord (94 ex) and hated them. I know the PSPEC and Forbidden shifters are quite a bit more expensive, but they are worth it.
Old Oct 20, 2007 | 08:00 AM
JGAccorn's Avatar
Default Re: short shifter (FarinaMotorsports)
A short shifter is fairly easy to make if you have decent fab skills. Mine is about 3" throw and solid as a mo fo! To make the actual shifter shorter do as follows. Pull the actual shifter lever out and there is 2 peices, one cast and one mild steel that the factory has welded together to make your shifter. Cut a 1/16" groove around the mild steel rod (shifter) just on top of the weld. Now pry and pull the 2 peices apart and you'll find that they are press fit and welded. Now just cut your shifter down about 1" - 1 1/4" and press it back together and seal the deal with a solid weld. Now you have a factory placement stubby shifter. Now take your stock shifter and cut the tab off that has the pin where the shift linkage attaches and weld it (along with some reinforcement tabs) higher up on the stick. I welded mine up about 1 1/2" higher. You could go higher and get shorter throw but you could run into "too hard" shifting. Now where the shift links mount to the base plate just cut that off, raise it about 1" to avoid linkage binding. Weld it all up and bolt it back in. I pulled the rubber bushings out from the base plate, and with some shorter bolts and washers I solid mounted the assembly. Now I have a very firm, smoothe short throw with $0 dollars outta pocket! Well maybe $10 for welding supplies. If anyone is interested let me know and i'll get some pics up. Once you pull your shifter assembly out and look at it you'll see what i'm talking about. Just cut it, it's only metal! Sounds like a lot of work but it takes maybe 1 hour and saves alot of $$! Besides, you made it and it's truly custom.
Old Oct 20, 2007 | 11:24 AM
Honduh Uhcord's Avatar
between the PSPEC and Forbidden short shifters have you heard any differences or anyone say ones better than the other?? have any preferences bewteen the 2?? because i was looking and by price they seem close but the PSPEC offers a package but it seems overpriced for the things you get with it (shift boot and ****) but i just wanted to know if one was better than the other?? thanks
Old Oct 20, 2007 | 02:01 PM
JGAccorn's Avatar
Default Re: short shifter (JGAccorn)
Ok so I just realized my homemade shifter is exacily like that adapters you guys speak of. Mine is just made. And a little smoother probably. I was installing shift cables in an Accord at work and just kinda thought it would work so I went home and started cutting. I think it is great. Very smoothe and very solid shifts.
Old Dec 19, 2008 | 01:00 PM
thirdayman's Avatar
hey i just joined because i have a 90 accord that i am working on. and the post by JGAccorn caught my eye. you said you could get some pics up. i would greatly appreciate it if you could thanks.
Old Dec 19, 2008 | 02:22 PM
flight50's Avatar
https://honda-tech.com/forums/honda-accord-1990-2002-2/pspec-short-shifter-1652699/
here is one of the sticky threads. from what i have read the past couple of years, these are the only two you should spend money one. expensive but most say its one of the best mods they added. sure you can make your own. if you know what your doing. but for most of us, your better off just paying the price and at least install it yourself.
http://forbiddenmotorsports.com/
http://www.pspectuning.com/9701P_tutorial.php
Old Dec 19, 2008 | 02:32 PM
thirdayman's Avatar
thanks, but i am perfectly capable of doing it myself. i just need some instructions or photos to follow by, and i dont have a lot of money to spend.
Old Dec 20, 2008 | 01:57 PM
khronicboy420's Avatar
i have a 95 accord if i get the forbidden short shifter then i do not have to get the adapter right? its either-or.
Old Dec 20, 2008 | 02:09 PM
propwdialogue's Avatar
correct.
Old Dec 20, 2008 | 09:12 PM
jweller's Avatar
I did this on my MS3, but it's the same for the accord. I didn't cut it down ans I don't like a short shifter, just a short throw.
hope it helps
Old Dec 21, 2008 | 10:05 AM
thirdayman's Avatar
thanks for the pics!
Honda4LifeB18C
Sep 2, 2017 01:15 PM
rayo53
Feb 6, 2014 11:56 AM
ghostlude99
Oct 7, 2008 05:35 PM
Zooper
Nov 27, 2005 06:33 AM
treplatano
16
Aug 12, 2005 10:50 PM
