Acura NSX Honda / Acura NSX 1990 - 2005 || Honda / Acura NSX 2017 -
17&18 inch rims, what the preferred width and offset?
Old Jul 5, 2005 | 07:06 PM
01-0720's Avatar
Default 17&18 inch rims, what the preferred width and offset?
when putting rims on an nsx and you put 17's in the front and 18's in the back
whats the preferred width and offset of each
and what the range either way you can go before the rims arent going
to fit correctly
not going to lower it to much, maybe a finger gap all around
thanks for any and all help
Old Jul 6, 2005 | 06:08 AM
nsxtasy's Avatar
H-T Order of Merit
Default Re: 17&18 inch rims, what the preferred width and offset? (01-0720)
<u>Front</u>:
215/40-17 tires on 17x7.5 wheels
<u>Rear</u>:
265/35-18 tires on 18x9.5 wheels ('91-93 NSX)
255/35-18 tires on 18x9.0 wheels ('94-05 NSX)
Although you can use either rear size on any year NSX, the rear size indicated is the best match for the traction control for that particular year. Similarly, either rear size tire will fit on either rear wheel width, but the indicated width is the best width for the particular tire size.
Offset depends on the particular wheel and the design of its spokes (so that they clear the brake calipers).
Old Jul 6, 2005 | 02:57 PM
01-0720's Avatar
Default Re: 17&18 inch rims, what the preferred width and offset? (nsxtasy)
excellent information
thank you
btw i was going to get volk racing te37's or volk gtu's
Old Jul 6, 2005 | 06:00 PM
Ponyboy's Avatar
Painting Masterpieces
I'm using Volk TE37's in 17x8.5 up front and 18x10.5 in back. I always forget the offset so I'll just the website where I picked them up: http://www.daliracing.com.
Oh and if you lower your NSX at all, the fronts will rub.
Old Jul 6, 2005 | 07:29 PM
nsxtasy's Avatar
H-T Order of Merit
Default Re: 17&18 inch rims, what the preferred width and offset? (Ponyboy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ponyboy &raquo;</TD></TR><TR><TD CLASS="quote">Oh and if you lower your NSX at all, the fronts will rub. </TD></TR></TABLE>
That's because you're using tires that are WAY too big, not the proper sizes that I mentioned above like most NSX owners with 17"/18" wheels use.
Old Jul 6, 2005 | 08:28 PM
Ponyboy's Avatar
"Proper" is relative.
Should have said, "if you use the sizes I did, your fronts will rub if you don't remove the wheel liners and pound out the wheel wells with a BUFF hammer."
How's that? I like cake (man, haven't said that in a LONG time).
Old Jul 6, 2005 | 09:20 PM
nsxtasy's Avatar
H-T Order of Merit
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ponyboy &raquo;</TD></TR><TR><TD CLASS="quote">How's that?</TD></TR></TABLE>
Better.
Old Jul 12, 2005 | 12:10 PM
97DGreenEx's Avatar
18'' with 6'' dish looks great, and lots of chrome, cant ahve to much chrome yo!
j_mee_5
Jan 30, 2010 02:01 PM
Accord1234
Jan 31, 2008 02:50 PM
GroovyNeilNeil
Honda S2000
13
Oct 14, 2004 10:47 AM
01-0720
Acura NSX
Apr 18, 2004 01:30 PM
SimbaDogg
Acura NSX
Feb 27, 2004 06:34 AM
