map sensor
Old Jul 5, 2005 | 06:59 PM
Mr.Death's Avatar
Default map sensor
I have a crx si with a d16z6(just installed) . My question is can I use the map sensor located on the firewall or does it have to be a obd1 92-95 map sensor. Thanks.
Old Jul 5, 2005 | 07:08 PM
Redline130's Avatar
Default Re: map sensor (Mr.Death)
Either one will work.
Old Jul 5, 2005 | 07:09 PM
Mach69's Avatar
That depends. If you are using the A6 intake manifold and A6 throttle body, you need to use the map sensor on the way.
If you are going to use the Z6 intake manifold and Z6 t/b, then you can rip that map sensor from the firewall off because the Z6 t/b has the map sensor built into it.
Also, The z6 intake manifold will not work with the A6 throttle body and visa versa.
zapzach
Apr 30, 2013 09:45 AM
B16A CRX
Jul 9, 2007 06:14 PM
175Shot4Door
Mar 2, 2007 08:26 AM
SLO Sol
Aug 23, 2006 08:04 PM
CimorelliCRX
May 14, 2003 09:38 AM
