lowering springs creeking
Look in between the spoke of your wheel to make sure the spring is seated correctly on the perch. If its not, thats your problem. If it is, spray some WD40 on the upper and lower control arm joints.
yea the struts are new so its not them. i had them done somewhere so im sure they are in right. i will try the WD40. couldn't hurt i guess. any other ideas would be welcome. thanks for your responses though
my springs creak. I know it is the springs 100%. they creaked so i put greas between the coils that touch....and the creak went away. I pulled the spring out, cleaned off all the grease, put the back in and the creak came back....annoying.
I actually took some wire loom (wire cover) and wraped the top part of the springs and it stoped the noise. It is ghetto, but it has worked for over 4 years
My DZ coilovers creak like crazy in the front. I looked at them many times and I'm sure they are together correctly. I'll try covering them with some vaccum tubing or some grease, thanks for the tip.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sickofitall1113 »</TD></TR><TR><TD CLASS="quote">racermech, you mean the plastic wire cover up stuff you use to hide wires in the engine bay and stuff? i want to try it.</TD></TR></TABLE>
Yup. I took my springs out and did it. You really have to work the wrap around the "dead coils" I wraped a long ways down at first, but then i figured out you only have to do the top 3 or 4 coils. Like i said this is pretty ghetto, but that down noise was killing me
2G0S0R1
Apr 10, 2007 06:51 PM
multitracks
Nov 1, 2005 03:41 PM
