Tuned my b16a dyno sheet inside.
Old Jul 5, 2005 | 05:10 PM
DeadVet's Avatar
Default Tuned my b16a dyno sheet inside.
Well I went to the dyno to get my b16a tuned. Its a stock b16a with a t3/to4e 50 trim with a .48 AR hot side, 2.5 down pipe and full 3 inch exhaust. We tuned it on 11psi to start with and made 275whp and 196 ft lbs. The A/F is pig rich right at 10s. We still need to play with the timing and lean it out a little bit. But here it is, let me know what you think, I dont have a scanner so i took a picture of it and wrote in what the numbers on the side were because they are hard to see. Hopefully when I go back to the dyno I will have a .63 AR housing and get rid of the .48 housing.
Modified by 1TurboHatch at 9:46 PM 7/5/2005
Old Jul 5, 2005 | 05:53 PM
mtber's Avatar
Default Re: Tuned my b16a dyno sheet inside. (1TurboHatch)
Looks good besides the pics
Old Jul 5, 2005 | 05:54 PM
DeadVet's Avatar
Default Re: Tuned my b16a dyno sheet inside. (mtber)
Haha yea the pics suck im going to try and go to the library tomorrow and scan them.
Old Jul 5, 2005 | 06:00 PM
SOHC_MShue's Avatar
If you tuned it why didn't you lean it out?
Old Jul 5, 2005 | 06:02 PM
DeadVet's Avatar
Default Re: Tuned my b16a dyno sheet inside. (SOHC_MShue)
ran out of time. I was at the dyno until 10:30pm
Old Jul 5, 2005 | 06:14 PM
eXcelonTypeR's Avatar
Why didnt you like the .48 a/r on the turbine??
Old Jul 5, 2005 | 06:25 PM
cuin9sec
Guest
Posts: n/a
Default Re: Tuned my b16a dyno sheet inside. (eXcelonTypeR)
Old Jul 5, 2005 | 07:34 PM
crx2fast's Avatar
Default Re: Tuned my b16a dyno sheet inside. (t67civic)
nice numbers man. very impresive for a 10 a/f
Old Jul 5, 2005 | 07:57 PM
HitEm'Up's Avatar
Nice!
Old Jul 5, 2005 | 11:00 PM
racinskittle's Avatar
Default Re: Tuned my b16a dyno sheet inside. (HitEm'Up)
Holy crap... Nice power!!!
Old Jul 6, 2005 | 02:35 AM
DeadVet's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by eXcelonTypeR &raquo;</TD></TR><TR><TD CLASS="quote">Why didnt you like the .48 a/r on the turbine??</TD></TR></TABLE>
Power started to fall off after 7400.
Old Jul 6, 2005 | 03:08 AM
Oh ok makes sense....when was boost coming on, its hard to tell form the graph
Old Jul 6, 2005 | 04:40 AM
-Trinitron-'s Avatar
yeah the .48 runs out of leg in the high rpm. It responds well on the low end though. Get the .63 and let us know how it goes!
Old Jul 6, 2005 | 08:18 AM
DeadVet's Avatar
Default Re: (-Trinitron-)
I think I am going to get the .63 housing before i finish up the tune so i dont have to do it twice.....The only problem is i cant find anyone that has a 5 bolt .63 AR housing with a stage 3 wheel used and http://www.turbonetics.com wants 200 for a new one.
BTW what do you guys feel is too much power for street tires (azenis) or a waste for the street period?
Old Jul 6, 2005 | 07:33 PM
DeadVet's Avatar
Default Re: (1TurboHatch)
I was looking at the graph and noticed how the torque peaks at 7400 along with the horsepower. I searched and found that most boosted b16s torque peaks earlier......Is this normal, what would cause it to peak at 7400?
89s1
Oct 21, 2005 10:44 AM
streetdzigns
Aug 9, 2005 02:43 PM
JM Performance
Nov 16, 2003 04:39 AM
