Drieability question OBD1 SOHC VTEC swap in 90' Std. h/b
OK guys here is the cenario:
1990 EF H/B STD
Frog jumper set up (OBD0 to OBD1)
JDM ZC SOHC VTEC with:
DC Sports 4-1 header (old EG spec)
AEM Cam gear (set at 0)
2000 EX Intake manifold
OBD1 GSR t-body
Milled (severely) and ported head
P28 ECU (virgin)
B&M Command flow FPR (set at 50psi @ WOT)
RC 270cc injectors
Heres the problem:
I can drive the car as hard as I want under 65% throttle with no issues, any gear any speed, any RPM.
If I exceed 65% throttle the car shuts off untill I lift to under 65%.
I have tried new TPS, MAP, ECU, Injectors, double checked all grounds and wiring.
Anybody ever run into this before? Any educated guesses?
I've done a search and came up empty handed, so any help would be much appreciated.
-Dylan
1990 EF H/B STD
OBD1 GSR t-body
P28 ECU (virgin)
RC 270cc injectors
Heres the problem:
-Dylan
Well for one, you're drowning the thing in fuel. Are you sure the TPS is working right... .45V closed and 3.50V or so open.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DS1 Motorsports »</TD></TR><TR><TD CLASS="quote">OK guys here is the cenario:
RC 270cc injectors
Why are you using 270's on a N/A car?
RC 270cc injectors
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Bunger »</TD></TR><TR><TD CLASS="quote">Well for one, you're drowning the thing in fuel. Are you sure the TPS is working right... .45V closed and 3.50V or so open.</TD></TR></TABLE>
I think its 4.5v at WOT.
Also, with the injectors. You STOCK unchipped ecu still thinks its the stock fuel injectors. I would chip your p28 telling it that it has larger injectors.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DS1 Motorsports »</TD></TR><TR><TD CLASS="quote">My AFRs were way lean so we added more fuel then maxed out the stockers.</TD></TR></TABLE>
You're using a stock P28... how were you maxing out the "stockers"? You have the fuel pressure above stock and 270cc injectors, probably around 30% too much fuel, how did you determine you're running lean?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mach69 »</TD></TR><TR><TD CLASS="quote">I think its 4.5v at WOT.</TD></TR></TABLE>
I gotta check the helm on this... it keeps coming up and I can't remember if it was 3.5 or 4.5...
Edit: Just checked it, you were right, its above 4.5V.
Wide band o2 (FJO)
I thought alot on that chip idea but if the pulse width is still set up for stock injectors all I should have is a over rich condition.. correct?
-D
-D
How did you find out you were running lean?
Larger injectors with increased fuel pressure and the stock mapping is gonna deliver a lot more fuel than you will need.
When I first started the car I took it out with the FJO in it to make sure I didn't have any major issues (the car is almost 15:1 compression/ estimated).
-D
-D
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DS1 Motorsports »</TD></TR><TR><TD CLASS="quote">Wide band o2 (FJO)
I thought alot on that chip idea but if the pulse width is still set up for stock injectors all I should have is a over rich condition.. correct?</TD></TR></TABLE>
I'm really surprised that you found a lean condition before, are you running a cat? And if so, where the readings after the cat?
A super over rich condition will wash out your rings, and you're loosing power to boot.
Bunger- I agree, mucho lost power, but i wanted to make sure i was clearly safe with fuel before i take the car to the dyno and risk blowing it up.
Wideband is before the cat.
My afrs are now about 11.7:1 across the board with is set-up like that for test miles on the chassis. (yes, rich, but very safe)
eda6- probably going AEM in the long run
-D
-D
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DS1 Motorsports »</TD></TR><TR><TD CLASS="quote">My afrs are now about 11.7:1 across the board with is set-up like that for test miles on the chassis. (yes, rich, but very safe)
VERY Rich for your setup. On a boost engine like 15+ psi, it should be 12:1. You raise that number to like 13:1. Try that.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DS1 Motorsports »</TD></TR><TR><TD CLASS="quote">My afrs are now about 11.7:1 across the board with is set-up like that for test miles on the chassis. (yes, rich, but very safe)</TD></TR></TABLE>
If you're running the conservative stock timing maps, you could probably even run a little leaner than 13.0:1... say 13.5:1 or so... depends how much you shaved the head and such.
Even with the AFR's on the rich side the car shouldn't completely shut off if the accelerator is over 65%.
the odd thig about this is the car remains "off" untill I lift off again even though the RPMs drop.
-Dylan
-Dylan
with AFRs at 11.7:1 it's not bogging under fuel.
This isn't a bog, literally it's like the car shuts down (igniton or fuel) untill you lift the throttle up past 60%
-Dylan
-Dylan
Sounds like your TPS wires are backwards...
You did an MPFI swap on that car, do the TPS wires go - Green - Red - Yellow
(Looking from the back of the plug, wires coming toward you, clip up)
Hmm, I swear I switched them, If your right I'm gonna pay pal you enought for a case of beer..
-Dylan
-Dylan
