AC Probs 95 EX 4 cyl.
Old Jul 5, 2005 | 03:07 PM
Accord95Lxxx's Avatar
Default AC Probs 95 EX 4 cyl.
the air was blowing so so cold...anyway had to put a new radiator in it, which was cake.
BUT now that i did that, the air will not blow cold at all....wtf??? everything is connected
even tried to charge it with 12oz but that did not do anything
im fresh out of ideas...?
Old Jul 5, 2005 | 03:13 PM
deserthonda's Avatar
Default Re: AC Probs 95 EX 4 cyl. (Accord95Lxxx)
you probably forgot to plug someting ,,, did you plug the compressor connector red wire back?? and now that you added freon you might have overcharged system //also chk the condensor fuse make sure it is not blown underhood fuse box......
Old Jul 5, 2005 | 03:24 PM
everythings pluged in....but i need to check the fuses
Old Jul 5, 2005 | 09:50 PM
fuses look good..tho i dont know how to test the relays in there...do i need an ohm meter or somthin
Old Jul 6, 2005 | 06:27 AM
NAiL05's Avatar
Default Re: (Accord95Lxxx)
As deserthonda said you overcharged it. If it was blowing cold before you put the radiator on why did you add more freon? You prob have to recharge your system.
Chiefsandybear
Jul 14, 2016 09:56 AM
emicha1
Honda Civic (2001 - 2005)
Feb 1, 2011 04:31 AM
perfpump
Honda Civic (2006 - 2015)
Apr 17, 2010 02:03 PM
twentyhurtz
Apr 8, 2006 08:51 AM
TheOne
May 7, 2003 09:15 AM
