06 accord SE blows warm air from driver side
Re: 06 accord SE blows warm air from driver side
You are probably low on refrigerant. The system doesn't get low, unless there is a leak. You could take your chances, and add some refrigerant (with stop leak) yourself, but that might cause more problems. It's up to you.
Some one told me the same thing about the refrigerant being low and I had it charged it didn't solve the problem so I did the DTC test and found it to be the thermostat motor assembly on the drivers side. on the 03/04 it's pretty easy to replace and get at plus you can find them online for 40-60 dollars. I hope this helps.
Check the system for refrigerant level and any leak in the hoses. The other reason can be faulty Air Compressor. It is easy to identify the fault, if you hear any voice when AC is switched on near the compressor, it means that compressor needs replacement. If everything is fine then go for inspecting fuse. If any faulty fuse is found replace it. You can check for fuse by viewing following image: http://ww2.justanswer.com/uploads/di...7-09-45_am.png
If everything is fine then only remedy is orifice tube connected between Condenser mounted in front of Radiator and Evaporator in passenger compartment.
I have replaced my daughter's compressor and some switch for the compressor...still no a/c. It will randomly start blowing after start up and an odd noise, no cold air on drivers side only passenger. Hoping to find an answer since she totes my 5 month grandaughter around.
woboer
06-23-2016 10:02 AM
