turbo interga wont start
Old Jul 5, 2005 | 01:41 PM
knomexx's Avatar
Default turbo interga wont start
im running six pounds of boost on a stock 91 integra motor. it ran great till i went to start it this morning and it just cranks. it ran fine when i parked it the night before. it has spark. it has fuel. and the compression seams very low. between 60 to 65 psi in all cylinders. anyone have any ideas what the problem could be
Old Jul 5, 2005 | 01:51 PM
5litereater's Avatar
Default Re: turbo interga wont start (knomexx)
well if you did the compression test correctly, theres a good chance your rings are shot.
Old Jul 5, 2005 | 01:59 PM
knomexx's Avatar
Default Re: turbo interga wont start (5litereater)
do you think the rings are stot even though it run great the night before and never blew any smoke out the exhaust
Old Jul 5, 2005 | 02:05 PM
D@nnY's Avatar
sounds like its off timing...check the cam timing it probably jumped. You might have bent valves...it might be fine
Old Jul 5, 2005 | 02:20 PM
knomexx's Avatar
Default Re: turbo interga wont start (D@nnY)
thanks you were right it jumped a tooth i spent so much time trying to figure this out. thanks again
MMMGIRL
Jan 28, 2014 02:22 PM
bvans
18
May 22, 2013 10:38 PM
JDMkid413
15
Jun 9, 2009 02:59 PM
rcoolb2002
Jul 18, 2005 02:28 PM
blah13
Sep 27, 2003 10:13 PM
