GT40R Spool time?
Old Jul 4, 2005 | 12:43 PM
wantboost's Avatar
Who is Mr Robot?
Default GT40R Spool time?
I'm looking at runing a true ball bearing gt40r on my build
darton mid sleeved b18a1.
84.5mm cp 9:1 pistons
Manley Rods
Knife-edged, balanced, micro-polished, camhfered and fluted crank
Fully built gsr head
-RPMnyc port job
ferrea valve guides
1mm supertech black nitride coated valves
ITR cams, aem cam gears (probably getting replaced with a custom grind)
The car will be street driven so i dont want it to be a total slug. i would be using the .95ar turbine housing as well. its either this or a gt35r but id rather have the gt40r
Old Jul 4, 2005 | 02:01 PM
b16sedan's Avatar
Default Re: GT40R Spool time? (wantboost)
Geoff's car with the .85 was coming on hard at about 6500, I would try and get the .85 if I were you.
Old Jul 4, 2005 | 02:02 PM
done's Avatar
Default Re: GT40R Spool time? (b16sedan)
NEVER!!!! mUAHHAHA
Old Jul 4, 2005 | 02:05 PM
wantboost's Avatar
Who is Mr Robot?
Default Re: GT40R Spool time? (Jordo@KAP)
hmm, so 6500 for almost 38 psi? not bad, makes me wonder what it takes for that turbo to make 500
jordo, youre just mad cos your car would never run on the old setup
Old Jul 4, 2005 | 03:57 PM
done's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by wantboost &raquo;</TD></TR><TR><TD CLASS="quote">hmm, so 6500 for almost 38 psi? not bad, makes me wonder what it takes for that turbo to make 500
jordo, youre just mad cos your car would never run on the old setup </TD></TR></TABLE>
wanna bet??
9psi
14.7psi
Old Jul 4, 2005 | 04:59 PM
mrbsponge's Avatar
are both of those being turned to almost 12 grand????
if so , its damn weird to see a dynograph start at like 5500 rpms!!!!!!
Old Jul 4, 2005 | 05:03 PM
tony1's Avatar
Default Re: (mrbsponge)
LOL
Old Jul 4, 2005 | 05:26 PM
null.'s Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mrbsponge &raquo;</TD></TR><TR><TD CLASS="quote">are both of those being turned to almost 12 grand????
if so , its damn weird to see a dynograph start at like 5500 rpms!!!!!!</TD></TR></TABLE>
it's mph buddy
Old Jul 4, 2005 | 06:08 PM
wantboost's Avatar
Who is Mr Robot?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jordo@KAP &raquo;</TD></TR><TR><TD CLASS="quote">
wanna bet??
lol, ok so it ran a little bit before you swapped manifolds and fixed the coolant problem, now it runs
ive been hearing from a few ppl that the gt40r is very very laggy. s im probably looking at getting a gt35r, im aiming for 500 on pump, maybe a little less
Old Jul 4, 2005 | 08:07 PM
Mase's Avatar
ive been hearing from a few ppl that the gt40r is very very laggy. s im probably looking at getting a gt35r, im aiming for 500 on pump, maybe a little less</TD></TR></TABLE>
i vote for gt35r.....
500 on pump eh?
Old Jul 4, 2005 | 08:25 PM
wantboost's Avatar
Who is Mr Robot?
Default Re: GT40R Spool time? (Mase)
mase, pm'd ya
Old Jul 4, 2005 | 08:45 PM
Justin Olson's Avatar
Geoff stated that the gt40r is less laggy then a t3/t4 57 trim. It really isn't that laggy. I would go with it.
Justin
Old Jul 4, 2005 | 08:50 PM
wantboost's Avatar
Who is Mr Robot?
Default Re: GT40R Spool time? (Justin Olson)
really? thats almost impossible, lol. so a .95ar t4 housing on a ball bearing platform spools faster than a run of the mill t3/t04e?
now what gear is geoff talking about? i can imagine in 4th and 5th it builds boost pretty fast, but what about 2nd and 3rd?
Old Jul 5, 2005 | 01:32 AM
Flamenco-T's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by wantboost &raquo;</TD></TR><TR><TD CLASS="quote">really? thats almost impossible, lol. so a .95ar t4 housing on a ball bearing platform spools faster than a run of the mill t3/t04e?
now what gear is geoff talking about? i can imagine in 4th and 5th it builds boost pretty fast, but what about 2nd and 3rd?</TD></TR></TABLE>
if you're still doing it for street car, stay with the GT35R. There are no reasons why GT35R can't give you the power that you're looking for. I seriously doubt that the GT40R spools faster than T3/4E. You'll be looking at 5800-6000 rpm ish for the GT40 R to spool, if your T3/4E takes that long to spool, something must be wrong.
I may be wrong, I have never had any experience with GT40 R, I went a step ahead to GT42R
stan
Old Jul 5, 2005 | 07:59 AM
Default Re: GT40R Spool time? (Flamenco-T)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Full-Race Geoff &raquo;</TD></TR><TR><TD CLASS="quote">to be honest, i think that this is definatley a factor. While a dual solenoid and co2 setup would help keep boost up, this pretty much has tested the limit of the GT40R compressor on a B series motor. A lot of people dont realize that this is not a monster turbo. This is the equivalent of a scaled up disco potato. It is not meant for drag racing, its just meant for crazy power and fast response. its a very efficent combination which results in a feeling of very little lag.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Full-Race Geoff &raquo;</TD></TR><TR><TD CLASS="quote">its no t25, but its livelier than a t3t04e 57 trim.
https://honda-tech.com/zero...age=3
Old Jul 5, 2005 | 10:00 AM
Full-Race Geoff's Avatar
all i was saying is that in my car, on the street, if i hit the gas at 2500rpm the car moves out faster than when it had a little t3t4 and a stock motor. i have a fully built motor with evrything i can think of doing to a honda. this setup's changes do not end at just the turbo...
Old Jul 5, 2005 | 10:02 AM
Turbocivic94's Avatar
Stan, How is the spool on GT42R
You guys are just insane
Old Jul 5, 2005 | 10:04 AM
Flamenco-T's Avatar
Default Re: GT40R Spool time? (Turbocivic94)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Turbocivic94 &raquo;</TD></TR><TR><TD CLASS="quote">Stan, How is the spool on GT42R
You guys are just insane </TD></TR></TABLE>
fully spooled at about 6500-6800 rpm
yes, we're insane
stan
Old Jul 5, 2005 | 10:10 AM
99_GS-T's Avatar
This is the smaller GT42R, correct? 94mm exducer...
Old Jul 5, 2005 | 10:14 AM
Flamenco-T's Avatar
Default Re: (99_GS-T)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 99_GS-T &raquo;</TD></TR><TR><TD CLASS="quote">This is the smaller GT42R, correct? 94mm exducer...</TD></TR></TABLE>
it's the largest compressor wheel, 94mm ex, 74mm in. 1.01 A/R on the hot side.
It's actually for sale...
stan
Old Jul 5, 2005 | 10:39 AM
Chrisv006's Avatar
Default Re: (Flamenco-T)
Ya'll are crazy lol..
GT40/42R's are gigantic...Supra turbos not &gt;2l turbos..
Never have anything below 6500-7000 rpm...
Just my 2c
-Chris
Old Jul 5, 2005 | 11:27 AM
BoostR41's Avatar
Default Re: (Chrisv006)
you don't need a 35R for 500whp on pump... look for dontblinks dyno sheet from his GT30R
Old Jul 5, 2005 | 11:34 AM
wantboost's Avatar
Who is Mr Robot?
Default Re: (BoostR41)
ok... it made 471 at 17 psi., the gt35r will make that at 14-15
remember, im also running this motor on race gas, so id max out a gt30r.
the gt35r is only 100 bucks more than the gt30r
Old Jul 5, 2005 | 01:02 PM
G
sh!t happens.
EMS EMS EMS EMS EMS EMS EMS EMS EMS EMS EMS EMS EMS EMS EMS EMS EMS EMS EMS EMS EMS EMS..... or just hondata..
GT35R or 40
Old Jul 5, 2005 | 01:04 PM
wantboost's Avatar
Who is Mr Robot?
Default Re: GT40R Spool time? (G"UNIT)
hondata and gt35r, hehe
