Swap h22a Accord 95
Old Jul 5, 2005 | 01:35 PM
Zair's Avatar
Default Swap h22a Accord 95
i just swap an h22a into my accord...
but the vtec dont work...
i want to know...where is the problem
thx
Old Jul 5, 2005 | 01:39 PM
i20ar's Avatar
Default Re: Swap h22a Accord 95 (Zair)
how do you know its not working? a bit more detail will help
Old Jul 5, 2005 | 01:43 PM
Zair's Avatar
First: Sorry for my English...i stay in Quebec...
I put the motor in the car...he run well...but...i feel no vtec...
Old Jul 5, 2005 | 01:54 PM
-Bionic-'s Avatar
Former Sponsor
Default Re: (Zair)
is your vss working?
i20ar's Avatar
Default Re: (Zair)
the was nothing wrong with your english. i was just asking for a little more detail about your swap. as for not feeling it.. have you ever been in a honda with vtec? its not like a turbo or anything so maybe it could be working but you just dont know what exactly your suposed to feel. how are you positive that it is not working?
Old Jul 5, 2005 | 02:26 PM
Zair's Avatar
i have already take a ride with a h22a...and i have feel the vtec...but now in my accord...i feel like nothing...but nothig...
Old Jul 5, 2005 | 02:30 PM
i20ar's Avatar
Default Re: (Zair)
are you using the ecu from the h22?
Old Jul 5, 2005 | 02:31 PM
Zair's Avatar
yes a p13
Old Jul 5, 2005 | 03:37 PM
NAiL05's Avatar
Default Re: (Zair)
Check your VTEC solenoid? Oil levels full?
Old Jul 5, 2005 | 04:12 PM
-Bionic-'s Avatar
Former Sponsor
Default Re: (NAiL05)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NAiL05 &raquo;</TD></TR><TR><TD CLASS="quote">Check your VTEC solenoid? Oil levels full?</TD></TR></TABLE>
Old Jul 5, 2005 | 06:56 PM
momstaxi's Avatar
Default Re: (-Bionic-)
wiring good? if you had to add vtec pins were they done correctley and in the correct locations?? is your car showing a "check engine light?" if so which codes?
Old Jul 6, 2005 | 12:20 AM
st95accord's Avatar
like momstaxi said make sure you check your wiring and that the vtec solenoid and pressure switch connected to the right plugs. if all wiring is ok including the wiring to the ecu then have you tried warming your car up or did you just take it down the road and back... if this is the case then vtec won't engage when the motor is cold. it needs to warmed up to at least the next tic mark above the cold position
JibrilsAuto
Mar 26, 2010 07:11 AM
95OdyLX
Mar 5, 2007 08:57 PM
spurge
Feb 9, 2006 05:45 PM
B-HuTcHiE
Nov 24, 2004 01:55 PM
Mike95lude
Aug 22, 2002 09:49 AM
