Best Oil Brand for my CB7
Old Jul 5, 2005 | 08:10 AM
90AccordTx's Avatar
Default Best Oil Brand for my CB7
Ok its time for me to change my oil, i was using penzoil but i dont think i should be using that, so do u guys know a better oil that i can use...
Old Jul 5, 2005 | 08:27 AM
BlueFang08's Avatar
Default Re: Best Oil Brand for my CB7 (90AccordTx)
I donno if its the best but if you run it pretty hard i would use Mobile 1.
Old Jul 5, 2005 | 11:36 AM
deserthonda's Avatar
ANY BRAND 10-W30 THE KEY IS TO REPLACE OIL + FILTER EVERY 3000 MILES , ENGINE WILL LAST MANY MANY MILES
Old Jul 5, 2005 | 09:48 PM
ptran's Avatar
Default Re: Best Oil Brand for my CB7 (deserthonda)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by deserthonda &raquo;</TD></TR><TR><TD CLASS="quote">ANY BRAND 10-W30 THE KEY IS TO REPLACE OIL + FILTER EVERY 3000 MILES , ENGINE WILL LAST MANY MANY MILES</TD></TR></TABLE>
10-30? I use 5-30 as according to the label i saw on the motor. which is better? btw, i would go with mobile 1 synthetic blend for the mileage vehilces.
Modified by ptran at 2:59 AM 7/7/2005
Old Jul 6, 2005 | 06:09 AM
NAiL05's Avatar
Default Re: Best Oil Brand for my CB7 (ptran)
The use of 10w30 and 5w30 depends on where you live. 5w30 is used in colder climates and 10w30 used in warmer climates.
For the oil part as people said above use 10w30 and change 3000 miles then you will be good.
Old Jul 6, 2005 | 07:44 AM
twkdCD595's Avatar
Default Re: Best Oil Brand for my CB7 (NAiL05)
I like mobil 1 and castrol blend 10-30.
Old Jul 6, 2005 | 09:47 AM
i20ar's Avatar
use 10W30 its soo hot in texas... ive heard almost all the oils are just about the same.... but i use castrol gtx
Old Jul 6, 2005 | 10:43 AM
93dx's Avatar
Default Re: Best Oil Brand for my CB7 (Dj14aZnS)
And what about that sticker by the engine (or the fuse box or air intake or...) that suggests you change the oil every 7000 miles. Do you think it's still better to change it twice as frequently as the sticker suggests?
Old Jul 6, 2005 | 11:24 AM
drifter_for_life06's Avatar
i dont know if its only guys with Nissans but it seems that nobody else uses Red Line Oils
thats top notch!
or if you can find(which is very very rare) the German Castrol oil
Old Jul 6, 2005 | 11:26 AM
if you want to really know what to do with your oils, head on over to
http://www.bobistheoilguy.com
Old Jul 6, 2005 | 03:19 PM
twkdCD595's Avatar
Default Re: (drifter_for_life06)
amsol is supposedly one of the best oil's around, which is kinda hard to find and somewhat expensive from what I have found locally. I also have used royal purple blend... great stuff too...
Old Jul 6, 2005 | 07:04 PM
royal purple is an OKAY engine oil, but whatever you do DO NOT waste the money on the Synchro-Max for transmissions, bad stuff not worth the cost
Old Jul 6, 2005 | 07:30 PM
Krut's Avatar
that doesnt say change the oil every 7000 it says change the oil filter every 7000, but that is wrong, the filter should be changed whenever the oil is changed.
20-EM2-05
Honda Civic (2001 - 2005)
60
Jul 8, 2010 04:25 AM
perpetualburn
12
Mar 5, 2007 05:13 PM
Kiniku Chunks!!!
Aug 24, 2006 12:39 PM
petrv
Jun 17, 2003 11:56 AM
B18cteg
May 29, 2003 05:09 PM
