Finally a Bubble on the front tire
Old Jul 5, 2005 | 05:47 AM
wpsadmin's Avatar
Default Finally a Bubble on the front tire
With all the pot holes i hit, yesterday i found a bubble on my right front tire.
Went to the tire shop, got the front two replaced. FALKEN $78/each, (different brand than what I have on the rear tires.)...
didn't get an alignment... now at 70mph, the steering wheel shakes a bit...
My rear tires still got threads left.
what you think, alignment a must or/and replace the rear tires also?
Old Jul 5, 2005 | 05:49 AM
Chris F's Avatar
Default Re: Finally a Bubble on the front tire (wpsadmin)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by wpsadmin &raquo;</TD></TR><TR><TD CLASS="quote">didn't get an alignment... now at 70mph, the steering wheel shakes a bit...
Out of round or out of balance tire. Could be either.
My mom had an out-of-round tire, drove her nuts for a while until it was replaced with another new one.
Old Jul 5, 2005 | 05:51 AM
wpsadmin's Avatar
Default Re: Finally a Bubble on the front tire (Chris F)
I watched the guy did the balance, and I think he did a good job on it.
Both are brand new tires.. out of round possibility??
Old Jul 5, 2005 | 06:02 AM
KetteringITR's Avatar
Well considering you said u hit a pothole, there is the possiblility that you bent your wheel. But my bets are on alignment issues.
Old Jul 5, 2005 | 07:32 AM
p nut's Avatar
I just got new tires last week and had the same issues (shaking after 60-70mph). Went back and had them rebalance the tires--problem solved. They don't always get it right the first time...
In your case, though, it might also be a bent wheel and alighnment, like others have said.
Old Jul 5, 2005 | 12:22 PM
ericlee303's Avatar
If you're hitting potholes hard, then probably your rim is bent. You can balance a bent rim, but doesn't mean it will roll properly.
Check and see if your rim is bent. This was my case when I hit a huge boulder with my Rota.
Andrew760
Jul 19, 2011 02:25 AM
em96civicex
Feb 22, 2008 01:09 PM
TOO MUCH TORQUE
Feb 8, 2007 11:57 PM
ilu
15
Jun 1, 2006 09:16 PM
Nice_Dc2r
Aug 25, 2003 03:26 AM
